VB Script to do some NCI stuff
This script might be "Rekd specific", but mayhaps some others do things the way I do, so I thought I'd share..
Here's what it does.. (read script comments as for "why" it does this..
Read all the NCI destinations on a file and store them in an array. Change the NCI's to match the MC9 name. Post that file to a specified post. Restore all the original NCI's, and restore the post.
'// Author: Matt Finley [email protected]
'// Date: 06/05/2004 09:16 AM
'// File Name: SavedNCI.vbs
'// Description: Changes all NCI destinations to match file name, posts that
'// file with the specified post, then changes the NCI and post
'// back to originals.
'// Why?: I program parts to run complete, multiple operations on a
'// single load. With up to 6 different operations on complex 4 axis
'// parts, it's often easier to do the setup using just one view/op
'// at a time. Then when the whole part is done, combine the programs
'// and run it as a single program. (PITA) I like to keep the integrety of
'// the seperated programs, with the seperate NCI destinations.
'// This script will do that, allowing me to structure my ops
'// effeciently for setup AND production runs. The script will also
'// change the post to the one specified, then revert back to the
'// original post.
Const DEF_POST1 = "HAAS VF3 POST 4AXIS PRE-STAGE.PST" ' Post to use
Dim MC9Path, NCIPath
Dim aryDest() ' holds NCI Paths until finished posting
Dim i ' counter
Call WriteString("Storing original NCI destinations..")
NCIPath = GetCurrentFileName() ' Set NCI to current MC9 file name
' -- Grab all the NCI destinations and store them
ReDim aryDest(GetOperationCount("")) ' Set array's size to number of ops
For i = 1 To GetOperationCount("") ' Cycle thru ops
arydest(i) = GetNciNameFromOperationID("", i) ' Store orignial NCI path
Call SetNciNameFromOperationID(i, NCIPath) ' Set new NCI path
Next
Call WriteString(" Done.")
Call Main() ' Post it!
' --Return NCI destinations to the originals
Call WriteString("Restoring original NCI Destinations...")
Call SetNciNameFromOperationID(i, arydest(i)) ' Retrieve original NCI path from array and apply
Next
Sub Main()
Dim strPath
Dim strCurrentPost
MC9Path = GetPathFromExtension("MC9")
If Not IsDrawing Then
ShowString "Umm.. how about you open up a file first? " & vbCrLf & vbCrLf & "Duh."
Exit Sub
End If
' -- Store current post
strCurrentPost = GetPostName
' -- Post to MC9's path
strPath = mc9path
If strPath = Null Then Exit Sub
Call SetPostName(DEF_POST1)
Call RunPostAll(strPath, False)
' -- Revert back to original post
Call SetPostName(strCurrentPost)
End Sub
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
IsDrawing = Ret
End Function
'Rekd
