I have a VBS that I run to create a new folder for a new part. I have it set up to ask for customers name then part number. Is there any way to have to create a table or something with all the big customers. then when the VB askes me for cutomer I could just put in 1 or 2 or 3 ....? Have the last option be other. If customer name = other then I would type in new name. Does this make any since????
Hello,
I believe there is a way (and not only one).
Here is how I would do it:
- create a txt file (like customers.txt). this file will contain your customers (every line - one customer).
- use functions like
  OpenAsTextStream
to read this file.
Here is some small example: of reading a text file line by line:
strfile = c:customer.txt  'path to your txt file
Set FSO2 = CreateObject("Scripting.FileSystemObject")
Set TS = FSO2.GetFile(strFile)
Set fsoTextFile = TS.OpenAsTextStream(1, -2)
While fsoTextFile.AtEndOfLine <> True
customer = fsoTextFile.ReadLine
Wend
- there is of course some more things to do:
every time the while loop reads a line the script should count the number of the line (like: customer # = line #), if the input number of the customer is some other text (for instance: new customer name) the script shoud not go into the read file loop. Instead it should write a new line into the file at the and of this file (look at the help file for the writing mathod).
- of course you can use similar methods to read the whole file and determine the number of customers, their names,... This information can help you improve user interface.
I believe there are some more experineced VBS gurus on this forum like BULLINESS, etc., who can help much more than I can (I believe they would do it some other, more efficient way).
I hope you will find this information useful.
Pkrzic
  • 5 weeks later...
Below is an example of reading a text file that has a list of customer names and assigning it to an array. The user is prompted for a number that represents a customer index in the list, and then the customer name is retrieved from the array via the index and displayed to the user.
There is no error checking at all so you would want to add that in a real world script.
'// Author: [email protected] Mick George
'// Date: 10/04/2006 09:07 AM
'// File Name: connormac.vbs
'// Description: Mastercam VB Script
'// Comments: Example of reading a flat file
' -- Edit path to suit
Const CUSTOMER_INFO = "C:Customer.txt"
' Text file has a simple list of customers
'Acme Industries
'CNC Software
'Joe Blow Inc.
' -- Start Script
Call Main
' Sub Declaration
Sub Main()
Dim CustomerList
Dim response
Dim selectedCustomer
' -- Build the list
CustomerList = GetCustomerList()
' -- Prompt for a #
If askNumber("Select a customer #", 1, 100, response) Then
' -- Get the customer
selectedCustomer = GetCustomerName(response, CustomerList)
If selectedCustomer = "" Then
' -- You could add this customer to your textfile
ShowString "New Customer!"
Else
' -- We have our customer name
ShowString selectedCustomer
End If
End If
End Sub
' -- Pass in the array of customers and the index and return
' -- the customers name at that index
Function GetCustomerName(idx, theList)
Dim i
For i = 1 To Ubound(theList)
If i = idx Then
GetCustomerName = theList(i)
Exit Function
End If
Next
' -- Not found so return null
GetCustomerName = ""
End Function
' -- Open text file and fill an array
' -- with the list of our customers
Function GetCustomerList()
Dim FSO, fsoStream
Dim CustomerList()
Dim i
Dim customer
Set FSO = CreateObject("Scripting.FileSystemObject")
Set fsoStream = FSO.OpenTextFile(CUSTOMER_INFO)
' -- Start at 1
i = 1
Do While fsoStream.AtEndOfStream <> True
customer = fsoStream.ReadLine
If Len(customer) > 0 Then
Redim Preserve CustomerList(i)
CustomerList(i) = customer
i = i + 1
End If
Loop
fsoStream.Close
' -- Return
GetCustomerList = CustomerList
End Function
