I have 2 VBS's that Mick George helped me with. 1 is
a read text file:
' -- Edit path to suit
Const CUSTOMER_INFO = "C:mcamxvbCustomerlist.txt"
' Text file has a simple list of customers
'Acme Industries
'CNC Software
'Joe Blow Inc.
' -- Start Script
Call Main
' Sub Declaration
Sub Main()
Dim CustomerList
Dim response
Dim selectedCustomer
' -- Build the list
CustomerList = GetCustomerList()
' -- Prompt for a #
If askNumber("Select a customer #", 1, 100, response) Then
' -- Get the customer
selectedCustomer = GetCustomerName(response, CustomerList)
If selectedCustomer = "" Then
' -- You could add this customer to your textfile
ShowString "New Customer!"
Else
' -- We have our customer name
ShowString selectedCustomer
End If
End If
End Sub
' -- Pass in the array of customers and the index and return
' -- the customers name at that index
Function GetCustomerName(idx, theList)
Dim i
For i = 1 To Ubound(theList)
If i = idx Then
GetCustomerName = theList(i)
Exit Function
End If
Next
' -- Not found so return null
GetCustomerName = ""
End Function
' -- Open text file and fill an array
' -- with the list of our customers
Function GetCustomerList()
Dim FSO, fsoStream
Dim CustomerList()
Dim i
Dim customer
Set FSO = CreateObject("Scripting.FileSystemObject")
Set fsoStream = FSO.OpenTextFile(CUSTOMER_INFO)
' -- Start at 1
i = 1
Do While fsoStream.AtEndOfStream <> True
customer = fsoStream.ReadLine
If Len(customer) > 0 Then
Redim Preserve CustomerList(i)
CustomerList(i) = customer
i = i + 1
End If
Loop
fsoStream.Close
' -- Return
GetCustomerList = CustomerList
End Function
This works great I just put in a number and it brings up a name of a customer.
What I am trying to do now is insert it into some other VBS's. The easiest is my create a folder vbs
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
On Error Resume Next
Dim companyname
Dim Program
<======starting right here
Do 'ask until a real company name is entered
companyname=Trim(AskString("Company Name?"))
Loop While companyname="Company Name?" Or companyname="((ESC))" Or companyname=""
<===============to right here I am trying to put in the answer from the 1st vbs.
Do 'ask until a real program number is used
Program=Trim(AskString("Part number?"))
Loop While Program="Part number?" Or Program="" Or Program="((ESC))"
If Not MakeFolders(companyname, Program) Then
ShowString "Failed to create folders, aborting script"
Exit Sub
End If
End Sub
' Function Declaration
Public Function MakeFolders(companyname, Program)
' -- Check to see if folders exist
Dim FSO
' -- This is kinda long winded but does the job
' -- NOTE: If you use an invalid character for a part number you'll have a problem!
If Not FSO.FolderExists("WAIKIKIMSPrograms"&companyname) Then
Call FSO.CreateFolder("WAIKIKIMSPrograms"&companyname)
End If
If Not FSO.FolderExists("WAIKIKIMSPrograms"&companyname & "" & Program) Then
Call FSO.CreateFolder("WAIKIKIMSPrograms"&companyname & "" & Program)
End If
If Not FSO.FolderExists("WAIKIKIMSPrograms"&companyname & "" & Program & "Source") Then
Call FSO.CreateFolder("WAIKIKIMSPrograms"&companyname & "" & Program & "Source")
End If
If Not FSO.FolderExists("WAIKIKIMSPrograms"&companyname & "" & Program & "Model Files") Then
Call FSO.CreateFolder("WAIKIKIMSPrograms"&companyname & "" & Program & "Model Files")
End If
If Not FSO.FolderExists("WAIKIKIMSPrograms"&companyname & "" & Program & "Docs") Then
Call FSO.CreateFolder("WAIKIKIMSPrograms"&companyname & "" & Program & "Docs")
End If
If Not FSO.FolderExists("WAIKIKIMSPrograms"&companyname & "" & Program & "NC Code") Then
Call FSO.CreateFolder("WAIKIKIMSPrograms"&companyname & "" & Program & "NC Code")
End If
If Not FSO.FolderExists("WAIKIKIMSPrograms" & companyname & "" & Program & "NC Code1000") Then
Call FSO.CreateFolder("WAIKIKIMSPrograms" & companyname & "" & Program & "NC Code1000")
End if
If Not FSO.FolderExists("WAIKIKIMSPrograms" & companyname & "" & Program & "NC CodeOP") Then
Call FSO.CreateFolder("WAIKIKIMSPrograms" & companyname & "" & Program & "NC CodeOP")
End if
If Err Then
MakeFolders = False
Else
MakeFolders = True
End If
End Function
At the place I have shown in the second one I need to be able to use the answer from the first VBS.
Thanks for looking.
You can add this function to the script the user runs:
Sub Include(sNameScript)
Dim FSO
Dim fsoInclude
Dim strMsg, strPath, strMC9
strPath = AddBackSlash(GetPathOfThisScript) & DEF_SCRIPT_FOLDER & "" & sNameScript
strMC9 = AddBackSlash(GetPath) & "VB"
Set fsoInclude = FSO.OpenTextFile(strPath)
If Err Then
strMsg = "The script '" & sNameScript & "' might be missing from your " & strMC9 & "" & DEF_SCRIPT_FOLDER & " folder"
strMsg = strMsg & vbCrLf
strMsg = strMsg & "This link will not function without this file. Make sure this file has not been moved or deleted."
strMsg = strMsg & "Contact your reseller for help or re-install the link to resolve this problem."
Call ShowString(strMsg)
Err.Clear
Else
With fsoInclude
ExecuteGlobal .ReadAll()
.Close
End With
End If
' -- Clean up
Set fsoInclude = Nothing
Set FSO = Nothing
End Sub
Then at the top of the main script add the line(s):
' -- Begin list of helper scripts
Include "KCDwATPGlobals.vbs"
Include "KCDwATPStringTable.vbs"
Include "KCDwATPFunctions.vbs"
Include "KCDwATPDatabase.vbs"
You can list as many scripts as you want here, what happens is that when the main script executes it will load all of the specified scripts at the same time and make the functions in them available to the main script. Make sure the scripts are in the same folder as the main script.
You will need to rename any Sub Main() calls in the included scripts to avoid unwanted behaviour.
