surface normals in 3D Models
5-axis flowline toolpaths contain I,J,K parameters as two points(X,Y,Z and U,V,W). In the postprocessor (in PMX0) the unit vector normal is available as VTOOLX,VTOOLY,VTOOLZ. Other 5-axis toolpaths may or may not contain surface normal vectors, depending on the type of toolpath. Do you want these vectors for machining or CMM's?
ok, now that I can access 5-axis flowline,
how do I get it to generate i, j, k values in the nc file? I have q simple surface model,
if i select he boundary lines, how do i get it to generate he i,j,k along with the x, y and z
values?
pma
Open the post you are using and look for....
arcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
You want to use 0 as your setting
What tool paths are you using?
What post?
What kind of machine?
Ver 9?
Ver X?
The more info the better to solve your problem.
can you be more specific as to what pst file these are located in?
The PST file is the post you are using.
ok here goes:
we don't really use a machine, we have a special laser projection application. it reads a part file with the x, y and z co-ordinates. it can also interpret i, j, k values. i would like to include the i,j,k values anytime they are there.
right now i was told to use a 5-axis machine type (5-AXIS TABLE - TABLE HORIZONTAL) , with surface finish toolpath (none i've selected produced the i,j,k values in the NC file).
The post file I've been playing with is the
Generic Fanuc 5X Mill.pst file.
We are running Mastercam X.
arcoutput is already set to 0 in the pst file.
once the NC file is generated, we xlate it to our part file format for our application.
I think you can do it by using post processor ,parsing nci text, or chook.
1. use processor
5axis move is gcode 11
gcode$=11
and tool vector variables are.
vtoolx$
vtooly$
vtoolz$
2. output nci text and use your program to parse it and output nc data.
read post document for nci text format..
3. read binary nci data by nci_manager() function,
and output data you need.
gcode = 11 is 5axis movement.
/// mill nci - 5 axis move
typedef struct
p_3d ep1, ///< move to point for cutter tip
ep2; ///< move to point for cutter center
real feed; ///< feed rate - positive value=feed, negative=feed unchanged
short path; ///< path position
short position; ///< start/end contour flag, stop, coolant change
p_3d snvec; ///< surface normal vector
} nci_mill_11;
I dont know if it is correct.
MPFAN.PST
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
fmt I 2 vtoolx$
fmt J 2 vtooly$
fmt K 2 vtoolz$
pvectorout
*vtoolx$,*vtooly$,*vtoolz$
prapidout #Output to NC of linear movement - rapid
pcan1, pbld, n$, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pvectorout, strcantext, scoolant, e$
plinout #Output to NC of linear movement - feed
pcan1, pbld, n$, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pvectorout, feed, strcantext, scoolant, e$
Is your toolpath 5ax flowline?
In MPFAN.PST
you see format #1 is 6 decimal places in metric.
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize ( smile.gif
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fmt I 1 vtoolx$
fmt J 1 vtooly$
fmt K 1 vtoolz$
and you may need changes around feed calculation..
It's been a long time since I edited .pst files last time..
got it to work with p_svec, q_svec and r_svec variables. now, how do i limit the number of points to generate in the nc file? would like just to trace around the boundary of the surface,
how do I specify to do this? no probelm if you dont know this one...
pma
