How to get the type of entity.
SigmaWave! What is your way to go through the db?
I use this to rotate all entities:
DL_DB_POS pos;
rewind_dl_db(ALIVE_BIT, L_ID|A_ID, &pos, false);
while (succf)
get_dl_db_ent(&pos, &e);
rotate_silent(&e.eptr, true, false, CenterPont, forgatasiszog, 1, &rotSuccf);
draw_ent(&e, e.color);
repaint_graphics();
if ((pos.u.db_ptr == db_start) | (pos.u.db_ptr == db_end)) {succf = false;}
BUT. This solution overflows with 1 ent. I mean one of my entities always rotate again (2times)... Why? What is what I left out?
I tried this way also:
succf = true;
ptr = db_start;
e_ptr = db_start;
dbEptr = db_end;
while (ptr != dbEptr)
get_ent(&ptr, &e_ptr, &e, ALIVE_BIT, L_ID|A_ID|S_ID|NB_ID, &succf);
repaint_graphics();
BUT. In this case one of my entities not rotate... Different than in my prev post... frown.gif
What is the proper way to use the rewrite_ent?
I use alone itself:
rewrite_ent(&e, 0);
I tried to use it to change color of an entity (in the same cycle with rotating). But no lot of luck.
Oh MyGod, all of thinks above were much easy in VB as a simple NET-Hook... cool.giffrown.gifheadscratch.gif
SigmaWave, it's nothing to say sorry about!!!
But Thank You for reply!!!
Today I tried some things:
I put the endptr watching in the first line in my cycle:
while (succf2)
if (ptr == dbEptr){succf2 = false;}
It works better as yesterday, but it's sometimes joking with me. Sometimes overflow with 1 entity but sometimes not... smile.gif
Maybe my given IGES playin' with me? Maybe I have to upgrade to MR2 SP1 SDK? No idea. Yet.
SigmaWave, if You want, you can mail me a small snippet... Many Thanks! rolleyes.gifcool.gif
I saw that, when I load my IGES and play a little with via Mastercam->xForm Translate/Rotate etc... And after then run my C-Hook (which rotate) everything fine... So I wrote a little cycle in my C-Hook before the rotating cycle. This short cycle only go trough the DB and rotate all entity with zero (yes, 0) degree... cool.gif
After than I can rotate/translate etc. well via my C-Hook... biggrin.gif
Projects for the next days: delete entity, change color/level... headscratch.gif
( Slowly this topic become my blog... biggrin.gif )
I think it is very easy to go through the DB.
Here we go:
DB_LIST_ENT_PTR d_ptr = db_start;
CString tempStr;
ent entity;
CList<CString, CString&> entList;
do
get_ent_from_eptr(d_ptr, &entity);
tempStr.Format(_T("idn: %d, ID: %d"), entity.ent_idn, entity.id);
entList.AddTail(tempStr);
d_ptr=d_ptr->next;
}while( d_ptr != db_end);
POSITION pos;
if (entList.GetCount() >0 )
pos = entList.GetHeadPosition();
while(pos)
tempStr = entList.GetAt(pos);
AfxMessageBox(tempStr);
entList.GetNext(pos);
I retrieved all the entity's ent_idn and ID, and store them in a CList. Then show them one by one.
The only problem of this code section is it is no good when there is nothing in DB_LIST. But It seems impossible, even it is an empty program.
Here is a method I've used if you are looking for something "specific".
Using the get_ent I can have the system match up on what I am looking for; entity type(s), only items that are "alive", etc.
#include "DbGet_ch.h"
// __ ScanArcs __
// Loads the supplieed vectors with the arc/circles in the database
// Returns: The number of arcs that where found
ulong ScanForArcs(std::vector<CArcEntity*>& vCircles,
std::vector<CArcEntity*>& vArcs)
DB_LIST_ENT_PTR ptr, found_ptr;
MC_BOOL succf;
ent entity;
ulong arc_count = 0;
ulong circle_count = 0;
CArcEntity *a; // CArcEntity is a 'package' Class to hold info about an Arc
hourglass_cursor();
ptr = db_start; // start at the beginning
for (;
// Find all the ARC entities
get_ent (&ptr, &found_ptr, &entity, ALIVE_BIT, A_ID, &succf);
if (!succf) // No more arcs
{ break; }
arc_count++; // Count the total number of Arcs in the database (Full circle or not)
a = new CArcEntity(entity.eptr, entity.u.ar.r, entity.u.ar.view);
if (requal(fabs(entity.u.ar.sw), TWO_PI)) // Is it a "full" (360 deg) Circle?
vCircles.push_back(a); // Add it to the Full Circle list
else // It is an Arc segment"
vArcs.push_back(a); // Add it the the Arc segment list
} // looping thru the database - finding all arc entities
restore_cursor();
return arc_count;
