rotary table feed rate multiplies tool feed by 9.836 ?
if set feed of tool in operations manager to 10 in per minute, when i generate gcode the rotary table rotates at F90.83 in/per min?
if i set to 2 in per minute, gcode output of rotary table is twice 9.836?
all other feeds and speeds , plunge ect are correct, only rotate table is wrong.
i tried changeing settings in machine definition manager, controll definition manager, ect, but no change.
diamiter of circylar part i am trying to cut is 11 inches. .25 flat endmill,,,,
tried generating code with each of those settings,
the dialouge box gives me three choices, deg/min/ f/min or inverse.
also tried the three 4th axis options, and three rotary table options, and changing inverse options, and maximum rotary table feed in machine control,,,
still same magic number 9.836. no matter what i change.
my work around is to divide my desired feed by 9.836 and put that number in the feed box, all other feeds for other axis ok.
MasterCam_MACH3B.pst
from the MACH3 website.
i am not using the "user created" one for mastercam.
maybe i have to go into the textfile to make changes to the way mastercam posts.
changes through the GUI seem to not stick correctly, feed in post only changes when i adjust tool feed in toolpath properties window. always by x 9.836
I will try diff. posts with rotary axis,
could be this,
found it in post file
#Rotary/Index variables
csav : 0 #C saved value
prvcabs : 0 #Saved cabs from pe_inc_calc,
#Used for rotary feed and direction calculations
cdelta : 0 #Calculation for angle change
rev : 0 #Calculation for deg/min
sav_rev : 0 #Saved revolution counter
indx_out : c9k #Rotation direction calculation
fmt 16 indx_mc #Rotation direction calculation
anybody anyidea what c9k, prvcabs, 16 indx_mc, would do ?
fixed it,
modified post file as .txt file, told it to not do any feedrate calculations for rotary table.
works for this sittuation but would need calculations for complex shapes where tool is travelingin towards and away from 0 on xy plane.
i think this is the code that calculates feed for rotary.
pfclc_deg_inv #Feedrate deg/min
circum = zabs * two * pi$
if cuttype = two & rot_on_x = three, circum = sqrt(xabs^2 + yabs^2) * two * pi$
if circum = zero, circum = c9k #Don't allow Zero
ldelta = sqrt((xabs-prv_xabs)^2+(yabs-prv_yabs)^2+(zabs-prv_zabs)^2)
cdelta = ((abs(cabs - prvcabs))/360)*circum
if ldelta = zero, cldelta = cdelta
else, cldelta = sqrt(cdelta^two + ldelta^two)
if cldelta = zero, cldelta = c9k
if use_frinv,
