c axis g-code output
hi, there
can anybody help me controlling the limit of c axis output not to exceed 360 degrees
a c-axis face contour toolpath outputs the following code in MastercamX3
N2320 X53.672 C360.
N2330 X53.669 C360.224
N2340 X53.659 C360.447
N2350 X53.643 C360.67
N2360 X53.62 C360.892
N2370 X53.591 C361.114
I don't want the C output to exceed 360 degrees
where can I do that in the MPLFAN.PST post or at any place
the attachment contains the toolpath
thanks
Well, this may get into the confusing realm of Machine Definition, Control Definition, post processor, or a combination of them. Check in your MD first and see if changing your settings here will help. This is for a 4th axis on a 3-axis vertical mill, but you could have something similar for your C-axis component of your lathe.
See if changing here gives you the output you want. I could be completely wrong, but it's worth a shot.
finally worked
I found it in an old version 9 post
1- add this sub to the post
p360_max_index #------- control the c axis output not to exceed 360 degrees
while cabs > 360, cabs = cabs - 360
while cabs < zero, cabs = cabs + 360
while cabs = 360, cabs = 0
cabs = abs(cabs)
2- and call it within pfcout and pcout
pfcout #Force C axis output
p360_max_index
pcout #C axis output
p360_max_index
thanks for you all :rolleyes:
Changing the output does not require post edits such as you have implemented.
This is what the 'scase' initializations are for (among other things):
#Machining position turret/spindle settings
# Switch strings based on turret position top/bottom-left/right and cut type.
# Turret position is based on the Mastercam settings (see lathtype).
# Strings are re-assigned for output in the routine psw_str_mult.
# The string variable sw_string holds the place position value to determine
# how to assign the strings.  Planes are relative to the view from Mastercam.
# Assign the 17 digit string following the alpha columns below:
# A - C axis, 1 = axis winds, 2 = axis signed, 3 = indexer, 4 = shortest direction
# B - Spindle direction, 0 = normal, 1 = reverse
# C - Plane 0 arc/comp, 0 = normal, 1 = switch
# D - Plane 1 arc/comp, 0 = normal, 1 = switch
# E - Plane 2 arc/comp, 0 = normal, 1 = switch
# F - Plane 0, 0 = G17, 1 = G19, 2 = G18
# G - Plane 1, 0 = G17, 1 = G19, 2 = G18
# H - Plane 2, 0 = G17, 1 = G19, 2 = G18
# Decimal (required)
# I - Plane 0, X axis, 0 = normal, 1 = switch sign from basic
# J - Plane 0, Y axis, 0 = normal, 1 = switch sign from basic
# K - Plane 0, Z axis, 0 = normal, 1 = switch sign from basic
# L - Plane 1, X axis, 0 = normal, 1 = switch sign from basic
# M - Plane 1, Y axis, 0 = normal, 1 = switch sign from basic
# N - Plane 1, Z axis, 0 = normal, 1 = switch sign from basic
# O - Plane 2, X axis, 0 = normal, 1 = switch sign from basic
# P - Plane 2, Y axis, 0 = normal, 1 = switch sign from basic
# Q - Plane 2, Z axis, 0 = normal, 1 = switch sign from basic
use_only_tl  : 1 	#Use only Top turret/Left spindle settings (below) for
        			#all Mastercam turret/spindle selections
        			#When configuring for multi-spindle/turret set to 0
#Columns-   	ABCDEFGH.IJKLMNOPQ #Turret/Spindle        	#Path Type
scase_tl_c1  : "10000222.000000000"  #Top turret/Left spindle, Turning cut
scase_tl_c2  : "11000012.000000000"  #Top turret/Left spindle, Right Face cut
scase_tl_c_2 : "11110012.000000000"  #Top turret/Left spindle, Left Face cut
scase_tl_c3  : "10010102.000000000"  #Top turret/Left spindle, Cross cut
scase_tl_c4c : "10000111.000000000"  #Top turret/Left spindle, Y axis subs. Cycle
scase_tl_c4  : "10000222.000000000"  #Top turret/Left spindle, Y axis subs.
scase_tl_c5  : "10000222.000000000"  #Top turret/Left spindle, Multisurf Rotary
scase_bl_c1  : "10000222.000000000"  #Bottom turret/Left spindle, Turning cut
scase_bl_c2  : "11000012.000000000"  #Bottom turret/Left spindle, Right Face cut
scase_bl_c_2 : "11110012.000000000"  #Bottom turret/Left spindle, Left Face cut
scase_bl_c3  : "10010102.000000000"  #Bottom turret/Left spindle, Cross cut
scase_bl_c4c : "10000111.000000000"  #Bottom turret/Left spindle, Y axis subs. Cycle
scase_bl_c4  : "10000222.000000000"  #Bottom turret/Left spindle, Y axis subs.
scase_bl_c5  : "10000222.000000000"  #Bottom turret/Left spindle, Multisurf Rotary
scase_tr_c1  : "10000222.000000000"  #Top turret/Right spindle, Turning cut
scase_tr_c2  : "11000012.000000000"  #Top turret/Right spindle, Right Face cut
scase_tr_c_2 : "11110012.000000000"  #Top turret/Right spindle, Left Face cut
scase_tr_c3  : "10010102.000000000"  #Top turret/Right spindle, Cross cut
scase_tr_c4c : "10000111.000000000"  #Top turret/Right spindle, Y axis subs. Cycle
scase_tr_c4  : "10000222.000000000"  #Top turret/Right spindle, Y axis subs.
scase_tr_c5  : "10000222.000000000"  #Top turret/Right spindle, Multisurf Rotary
scase_br_c1  : "10000222.000000000"  #Bottom turret/Right spindle, Turning cut
scase_br_c2  : "11000012.000000000"  #Bottom turret/Right spindle, Right Face cut
scase_br_c_2 : "11110012.000000000"  #Bottom turret/Right spindle, Right Face cut
scase_br_c3  : "10010102.000000000"  #Bottom turret/Right spindle, Cross cut
scase_br_c4c : "10000111.000000000"  #Bottom turret/Right spindle, Y axis subs. Cycle
scase_br_c4  : "10000222.000000000"  #Bottom turret/Right spindle, Y axis subs.
scase_br_c5  : "10000222.000000000"  #Bottom turret/Right spindle, Multisurf Rotary
Change the first value in the string (column "A") as needed to determine C output.
If 'use_only_tl' is set to 1 as above, just change the bolded values here:
using these settings to match the desired output:
