macro post need help
fmt Z 2 u_depth # User island depth
fmt 2 m_step # Max rough step size
fmt Z 2 n_cut # Numbr of finish cut
fmt Z 2 z_cut # Z of finish cut
fmt Z 2 k_down # Keep tool down
fmt Z 2 d_cut # Depth cut
fmt Z 2 d_order # Depth cut order
fmt 2 o_sub # Output subprogram lable
fmt 2 m_pass # Multi pass
fmt Z 2 n_rough # Number of roughing cut
fmt Z 2 d_rough # Depth of roughing cut
fmt Z 2 n_finish # Number of finish cut
fmt Z 2 d_finish # Depth of finish cut
fmt Z 2 k_down_1 # Keep tool down
fmt Z 2 t_depth # Toolpath depth
fmt Z 2 d_mode # Depth
fmt Z 2 t_stock # Top of stock
fmt Z 2 f_plan # Feed plan
fmt Z 2 f_mode # Feed plan mode
fmt Z 2 t_stock_mode # Top of stock mode
fmt Z 2 c_type # Contour type
fmt Z 2 t_wall # Taper wall
fmt Z 2 t_angle # Taper angle
fmt Z 2 d_order_c # Depth cut order
pparameter$ # Run parameter table
if prmcode$ = 10064, u_depth = rpar(sparameter$,1) # User island depth
if prmcode$ = 10065, m_step = rpar(sparameter$,1) # Max rough step size
if prmcode$ = 10066, n_cut = rpar(sparameter$,1) # Numbr of finish cut
if prmcode$ = 10067, z_cut = rpar(sparameter$,1) # Z of finish cut
if prmcode$ = 10069, k_down = rpar(sparameter$,1) # Keep tool down
if prmcode$ = 15211, d_cut = rpar(sparameter$,1) # Depth cut
if prmcode$ = 15379, d_order = rpar(sparameter$,6) # Depth cut order
if prmcode$ = 15738, o_sub = rpar(sparameter$,1) # Output subprogram lable
if prmcode$ = 15214, m_pass = rpar(sparameter$,1) # Multi pass
if prmcode$ = 15560, n_rough = rpar(sparameter$,1) # Number of roughing cut
if prmcode$ = 15561, d_rough = rpar(sparameter$,1) # Depth of roughing cut
if prmcode$ = 15380, n_finish = rpar(sparameter$,1) # Number of finish cut
if prmcode$ = 15381, d_finish = rpar(sparameter$,1) # Depth of finish cut
if prmcode$ = 15385, k_down_1 = rpar(sparameter$,1) # Keep tool down
if prmcode$ = 10029, t_depth = rpar(sparameter$,1) # Toolpath depth
if prmcode$ = 15103, d_mode = rpar(sparameter$,1) # Depth
if prmcode$ = 10027, t_stock = rpar(sparameter$,1) # Top of stock
if prmcode$ = 10024, f_plan = rpar(sparameter$,1) # Feed plan
if prmcode$ = 10025, f_mode = rpar(sparameter$,1) # Feed plan mode
if prmcode$ = 10028, t_stock_mode = rpar(sparameter$,1) # Top of stock mode
if prmcode$ = 12014, c_type = rpar(sparameter$,1) # Contour type
if prmcode$ = 12015, t_wall = rpar(sparameter$,1) # Taper wall
if prmcode$ = 12016, t_angle = rpar(sparameter$,1) # Taper angle
if prmcode$ = 12017, d_order_c = rpar(sparameter$,6) # Depth cut order
pwrttparam$ #Information from parameters
u_depth : 0 # User island depth
m_step : 0 # Max rough step size
n_cut : 0 # Numbr of finish cut
z_cut : 0 # Z of finish cut
k_down : 0 # Keep tool down
d_cut : 0 # Depth cut
d_order : 0 # Depth cut order
o_sub : 0 # Output subprogram lable
m_pass : 0 # Multi pass
n_rough : 0 # Number of roughing cut
d_rough : 0 # Depth of roughing cut
n_finish : 0 # Number of finish cut
d_finish : 0 # Depth of finish cut
k_down_1 : 0 # Keep tool down
t_depth : 0 # Toolpath depth
d_mode : 0 # Depth
t_stock : 0 # Top of stock
f_plan : 0 # Feed plan
f_mode : 0 # Feed plan mode
t_stock_mode : 0 # Top of stock mode
c_type : 0 # Contour type
t_wall : 0 # Taper wall
t_angle : 0 # Taper angle
d_order_c : 0 # Depth cut order
looper : 0
z_sav : 0
d_cut_flag : 0
fmt 2 a_a
fmt 2 a_b
fmt 2 a_c
fmt Z 2 a_d
prapidout #Output to NC of linear movement - rapid
if d_cut = 1,
a_a = t_stock
a_b = t_depth
a_c = m_step
a_d = f_plan + t_stock
"#100 = ", *a_a, "(TOP OF STOCK)", e$
"#101 = ", *a_b, "(DEPTH)", e$
"#102 = ", *a_c, "(MAX CUT DEPTH)", e$
"WHILE[#100",[if a_b > 0,"LE", else, "GE"], *a_b,"]DO1", e$
`sgcode, *a_d, e$
d_cut_flag = 1
d_cut = 0
else,
sav_gcode = gcode$
if convert_rpd$ = one,
gcode$ = one
feed = maxfeedpm
ipr_type = zero
pcan1, pbld, sgplane, `sgcode, [if gcode$ = 1, sgfeed], sgabsinc, pccdia,
pxout, pyout, pzout, pcout, [if gcode$ = 1, `feed], strcantext, scoolant, e$
gcode$ = sav_gcode
if d_cut_flag = 1,
a_a = t_stock
a_b = t_depth
a_c = m_step
"#100 = #100 - ", *m_step, e$
"END1", e$
O0001
G00G17G20G40G80G90
G91G28Z0.
(COMPENSATION TYPE - COMPUTER)
N101T1M06(DEFINE TOOL NAMES)
(MAX - Z8.)
(MIN - Z-2.)
G00G17G90G53X-.3709Y.7657S0M05
G43H1Z8.M08
#100 = 0.(TOP OF STOCK)
#101 = -2.(DEPTH)
#102 = .5(MAX CUT DEPTH)
WHILE[#100GE-2.]DO1
Z.2
#100 = #100 - .5
END1
G94G01Z-.5F0.
X-.0087Y.6686F.01
G03X.0302Y.6635I.0389J.1449
G01X.2823
G02X.7823Y.1635I0.J-.5
G01Y-.1752
G02X.2823Y-.6752I-.5J0.
G01X-.2219
G02X-.7219Y-.1752I0.J.5
G01Y.1635
G02X-.2219Y.6635I.5J0.
G01X.0302
G03X.069Y.6686I0.J.15
G01X.4312Y.7657
G00Z8.
#100 = #100 - .5
END1
X-.3709
#100 = #100 - .5<----------------------------suppress below to M05
END1
#100 = 0.
#101 = -2.
#102 = .5
WHILE[#100GE-2.]DO1
Z.2
#100 = #100 - .5
END1
G01Z-1.F0.
X-.0087Y.6686F.01
G01X.2823
G01Y-.1752
G01X-.2219
G01Y.1635
G01X.0302
G01X.4312Y.7657
G00Z8.
#100 = #100 - .5
END1
X-.3709
#100 = #100 - .5
END1
#100 = 0.
#101 = -2.
#102 = .5
WHILE[#100GE-2.]DO1
Z.2
#100 = #100 - .5
END1
G01Z-1.5F0.
X-.0087Y.6686F.01
G01X.2823
G01Y-.1752
G01X-.2219
G01Y.1635
G01X.0302
G01X.4312Y.7657
G00Z8.
#100 = #100 - .5
END1
X-.3709
#100 = #100 - .5
END1
#100 = 0.
#101 = -2.
#102 = .5
WHILE[#100GE-2.]DO1
Z.2
#100 = #100 - .5
END1
G01Z-2.F0.
X-.0087Y.6686F.01
G01X.2823
G01Y-.1752
G01X-.2219
G01Y.1635
G01X.0302
G01X.4312Y.7657
G00Z8.M09
#100 = #100 - .5
END1
M05
G91G28Z0.
G28Y0.
G90
