Stage tool Problem
Hi All
I have a Mazak FH8800 and I have been modifying the generic Fanuc 3/4 axis post to suit.
I have most of it working properly now.
However when it comes to the pre stage tool I have a slight problem
My Mastercam test piece is a cube that has a simple contour machining on each face to capture the B axis output and also a drilling operation.
The contour machining uses T51 and there are four operation where I have ticked the force tool change in the operation parameters for each operation and this generates a tool change code so I can restart on any face.
The problem is that it is prestaging the Drill which is T2 directly after the first operation which makes the tool magazine index pocket 2, to the pre select tool change arm. When the second contour operation starts and the forced tool change code is read it reads the T51 and index the magazine to T51 and then back to T2.... This occurs at every operation
Here is what the Nc code looks like
O12345678(POST SETUP)
( DATE=DD-MM-YY - 28-07-11 TIME=HH:MM - 08:35)
( T51 | 54MM SANDVIK LONG EDGE ENDMILL )
( T2 | DIA 20.01MM GUHRING HT DRILL )
( T3 | 20MM MITSUBISHI ENDMILL )
G21
G0 G17 G40 G49 G80 G90
( 54MM SANDVIK LONG EDGE ENDMILL )
T51
M6
T2
B000
G0 G90 G54 X185. Y54. S800 M3
This is what I would think and Like it to look like untill the final contour oepration and only then preselet T2
G21
T51
M6
T51
B000
Is there a way to instruct the post to realize that due to the four contour operations that the actual next tool is the curernt tool until the last contour operation and only then preselect T2
Hope I have made the problem clear. It does cause alot of unecessary magazine movement.
  • 1 year later...
