post comments help, please...
Hi Jeff, Keith!
very appreciated for your help...
i just download mpmaster.* , and run the test, both horizontal and vertical posts do the same thing,
they can not see the whole blocks in that tool??
they just only look at the first block only,
attached here is the test file, when you run tool path group1, they will say : (COMPENSATION TYPE - COMPUTER)
that is not right, because that tool has wear comp: N145 G41 D31 Y1.375 ....
if you run tool path group2 , it says nothing, but this tool has wear comp. too?? : N75 G41 D31 Y1.375....
i might have to give it up , and use the manual comment!!! :(
Thanks alot for your time..
TEST1.MCX-5
Ok so how about having it tell you WHEN the comp is turned on... like next to an operation comment, and not in the tool list?
Something like this:
G80M09
M05
G91G28Z0.
M01
(THREAD MILL)
(COMP TYPE-WEAR COMP) <----------------------------
N300T3M06( 3/4-10 THREADMILL)
(MAX - Z.5)
(MIN - Z-1.05)
G00G90G54X0.Y0.S2500M03
G43H3Z.5
/M08
T1
Z.1
I think this will be your best bet, getting things to work the way you want in the tooltable is not easy...
Ok
first define the variable
fmt 	4   lanvucomp	# comptype
then give it a value
   		if prmcode$ = 15346, lanvucomp = rpar(sparameter$,1)
Then make it output what you want, where you want... I put this right at the top of the ptlchg_com postblock, you can put it wherever you want and change the text inside the parenthesis to say whatever you want.
ptlchg_com  	#Tool change common blocks
  	if lanvucomp = 0, pbld, "(COMPUTER COMPENSATION)", e$
  	if lanvucomp = 1, pbld, "(CONTROL COMPENSATION)", e$
  	if lanvucomp = 2, pbld, "(WEAR COMPENSATION)", e$
  	if lanvucomp = 3, pbld, "(REVERSE WEAR COMPENSATION)", e$
  	if lanvucomp = 4, pbld, "(COMPENSATION OFF)", e$
here is what I get out of that...
N670 M00
N680 T542 M06
N690 M00
( CONFIRM T542 H542 D542 DIA = 42.0000 )
N700 M11 (UNLOCK C)
N710 M11 (UNLOCK
N720 G00 G17 G90 G54 C0. B0. X-89.4245 Y-39.4084 S545 M03
N730 M10 (LOCK C)
N740 M10 (LOCK
N750 G43 H542 Z.25
N760 Z.2
