quick way to change geo, for part family programs
Oops my bad,
I would say write a custom macro, but it could be very time consuming. It would be nice if cam systems and parametric programming coexisted.
I normally do this for small part families 5-10 parts.
1 . Create each part on a layer.
2. Create toolpaths for first part.
3. Export toolpaths and name group as Part #1234 Family.
4. Then, do a new machine group with the same machine.
5. Import toolpath operations (as Part #1234 Family).
6. Set program number and file name .
7. Turn on second layer, and re-chain new geometry.
8. After you do every part then you can post 1 part or the hole family.
For large part families, I do the following,
1 . Create 1st part on a layer.
3. Post part program.
4. In the editor, create an custom macro for each dimension by adding a macro variable and save as master program.
5. Then create a logic program for the part numbers that will set the variable dimensions based on the first part.
This is just an example of one tool and the logic program for part numbers. Here I only did (Z axis), but it works for (X) as well.
Note: This program makes 4 parts with different (Z) lengths based off of the part programmed.
:8000(XXXX MAIN PROG.)
G20
G0G10L2P0X0.Z11.3512
G0G10L2P1X0.Z0.
(ENTER PART # ON MACRO VAR. #500)
G65P2525(GET PART # MACRO)
M38
M434
M01
N2G0G28U0.(TOOL - 2 OFFSET - 2)
G0T0299
M10(CHUCK CLAMP)
G50S#101
G96S#102M3
G0G54Z[11.9312+#116]M8
X3.
X.968
G1Z[11.8312+#116]F#103
Z[8.0337+#116]
X1.42
G0Z[11.9312+#116]
X.716
G1Z[11.8312+#116]
Z[10.5112+#116]
X.7974
Z[9.8789+#116]
G3X.8119Z[9.85+#116]R.0612
G1Z[8.0337+#116]
X1.188
G0Z[11.9312+#116]
X.4641
G1Z[11.8312+#116]
Z[11.1104+#116]
X.5581Z[11.0634+#116]
Z[10.5112+#116]
X.936
G0X3.M9
M81
G0G28U0.M5
G0T0288
M01
:2525(PART FAMILY)
(GET PART #)
(PART A = 0.)
(PART B = 1.25)
(PART C = 2.5)
(PART D = 3.75)
IF[#500EQ1001.]GOTO1001
IF[#500EQ1002.]GOTO1002
IF[#500EQ1003.]GOTO1003
IF[#500EQ1004.]GOTO1004
GOTO3000
N1001(PART A)
#101=[1000*3] (MAX RPM)
#102=[100*6] (SFPM)
#103=[.001*12] (IPR)
#116=0.(LENGTH A)
M99
N1002(PART B)
#102=[100*6] (SFPM)
#116=1.25(LENGTH A)
M99
N1003(PART C)
#102=[100*6] (SFPM)
#116=2.5(LENGTH A)
M99
N1004(PART D)
#102=[100*6] (SFPM)
#116=3.75(LENGTH A)
M99
N3000(ALARM)
#3000=10(NO PART # SET VAR#500)
M99
