Importing SLDPRT into MCX-5
Hello Forum,
My name is Matt and this is my first post. I work in kitchener and have a small vbs program that I wanted to create since we do this string of instructions over and over.
Pretty much we want to be able to have a hotkey that will import a SLDPRT file into mastercam and resave it in another directory with the same name so we can edit it. We dont want to edit the original file, just import and resave. I have no real VB experience since college and am unsure how to do this. Any pointers are appreciated.
Thank-you Forum.
Hello Forum,
Thank-you Forum.
Also I figure this is really close to what I wanted to do.
' * Script Name: Batch Import DXF Files.vbs
' * Written By: Mick George [email protected]
' * Date: August 15 2002
' * Dependency: Microsoft Scripting Runtime (scrrun.dll)
' * Microsoft Windows Scripting Host (WScript.exe)
' * Function: Batch Import dxf files and save as native mastercam drawings
' * Select folder containing dxf files and select a folder to save drawings to
' * Updated: Mick George added LCase() call to correctly identify dxf file extension.
' * January 21 2003
' * Updated: Mick George added call to PROGRESS class
Include "CProgress.vbs"
Public Const DEF_CENTERED = " "
' -- Kick off script --
Call Main
' Sub Declaration
Sub main()
Dim FSO ' -- File System Object
Dim fsoDXFFolder ' -- Folder containing DXF Files
Dim fsoSaveToFolder ' -- Folder to save *.MC9 files
Dim fsoFiles ' -- Files located in selected folder
Dim fsoDXF ' -- A dxf File
Dim strDXFPath ' -- Return value of selected folder containing dxf files
Dim strSavePath ' -- Return value of selected folder to save files to
Dim blnOkToGo ' -- Flag
Dim strPrompt
Dim strMC ' -- Stores a Mastercam filename from a dxf filename
Dim CProgressBar ' -- Our progressbox
' -- Prompt user for a folder containing dxf files
strDXFPath = BrowseForFolder("Choose DXF Files Folder")
' -- Make sure a valid folder was selected
If IsNull(strDXFPath) Then
ShowString "Invalid Folder Selection"
Exit Sub
Else
' -- Prompt user for a save folder
strSavePath = BrowseForFolder("Save Drawings")
If IsNull(strSavePath) Then
Exit Sub
End If
' -- Create an instance of a File System Object
Set FSO = CreateObject("Scripting.FileSystemObject")
' -- Get the selected folder
Set fsoDXFFolder = FSO.GetFolder(strDXFPath)
' -- Get all files in this folder
Set fsoFiles = fsoDXFFolder.Files
' -- Make sure we have some files
If fsoFiles.Count = 0 Then
ShowString "There are no files in the selected folder"
Exit Sub
Else
' -- Initialize to be sure
blnOkToGo = False
' -- Make sure there is at least one dxf file
For Each fsoDXF In fsoFiles
' -- dxf file?
If Right(LCase(fsoDXF.Name), 3) = "dxf" Then
' -- ok to go
blnOkToGo = True
Exit For
End If
Next
If blnOkToGo Then
Dim blnRet
strPrompt = fsoFiles.Count & " dxf files found" & DEF_CENTERED
strPrompt = strPrompt & vbCrLf
strPrompt = strPrompt & "Do you wish to continue?" & DEF_CENTERED
blnRet = askYesNo(strPrompt)
If blnRet = mcMSG_NO Then Exit Sub
' -- Check for Root
Call AddBackSlash(strSavePath)
' -- Erase the Mastercam prompt area at the bottom of the Mastercam window and Menus
Call ClearMenuAndPrompts
' -- Clear screen
Call ResetAll
Set CProgressBar = New PROGRESS
CProgressBar.Show 500, 100, 550, 550
' -- Convert each dxf file
' -- dxf file?
CProgressBar.Caption "Converting " & fsoDXF.Name & "..."
' -- Display current file in prompt area
Call WriteString("Converting " & fsoDXF.Name & "...")
' -- Import this DXF file into the current Mastercam session
Call ReadDXF(fsoDXF.Path)
' -- Fit screen
Call RepaintScreen(True)
' -- Build Mastercam filename
strMC = Mid(fsoDXF.Name, 1, InStrRev(fsoDXF.Name, "."))
' -- Build fullpath to folder
strMC = strSavePath & strMC & "MC9"
' -- Save the current Mastercam file
If Not SaveMCAs(strMC, True) Then
If Not askYesNo("Unable to save file '" & strMC & "' Do you wish to continue?" & DEF_CENTERED) Then
Exit For
End If
End If
' -- Clear screen
Call ResetAll
End If
Next
Call ResetAll
CProgressBar.Caption "Process Complete"
CProgressBar.Shutdown
' -- If blnOkToGo
Else
ShowString "There are no dxf files in the selected folder"
End If
End If
End If
Set CProgressBar = Nothing
End Sub
' Function Declaration
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "\" Then sPath = sPath & "\"
AddBackSlash = sPath
End Function
Function BrowseForFolder(strPrompt)
On Error Resume Next
Dim objShell, objFolder, intColonPos, objWshShell
Set objWshShell = CreateObject("WScript.Shell")
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.BrowseForFolder(&H0&, strPrompt, &H1&)
BrowseForFolder = objFolder.ParentFolder.ParseName(objFolder.Title).Path
If Err.Number <> 0 Then
BrowseForFolder = Null 'will be null of no special case applies
If objFolder.Title = "Desktop" Then
BrowseForFolder = objWshShell.SpecialFolders("Desktop")
End If
intColonPos = InStr(objFolder.Title, ":")
If intColonPos > 0 Then
BrowseForFolder = Mid(objFolder.Title, intColonPos - 1, 2) & "\"
End If
End If
End Function
Sub ResetAll()
' -- Clear screen
Call NewMC(False)
' -- Fit screen
' -- Clear prompt area
Call ClearPromptLines
End Sub
' '// Sub Declaration
Sub Include(sNameScript)
Dim FSO
Dim fsoInclude
sNameScript = GetPathOfThisScript & sNameScript
Set fsoInclude = FSO.OpenTextFile(sNameScript)
With fsoInclude
ExecuteGlobal .ReadAll()
.Close
End With
' -- Clean up
Set fsoInclude = Nothing
Set FSO = Nothing
End Sub
Going through this reminds me why I dislike coding in VB Script - YUCK! :(
The attached VB Script [ Import SLDPRT Files.vbs ]
is a revised version oif the Batch DXF inport.
It prompts the user for a folder containing .SDLPRT files
and then for an output folder to place the resulting .MCX-5 files into.
And process ALL of the .SLDPRT files in the source folder into .MCX-5 files that are placed in the destination folder.
This Browse for Folder (twice!) is OK for dong batch conversion, but for a quick "do this file".
*NOTE* This sctript does not prompt the user to save any currently loaded data when it starts up!
Of course VB Scripts cannot be "directly" launched via a toolbar icon and/or keystroke.
To accomplish that, you need to the the ScripLinker AddOn
Import SLDPRT Files (VBS).zip
Thank you so much Roger. That is a great start. There are a few more things I want to add so I will start on that.
I did notice that this opens the files, and not imports it. Is there a way to import instead?
Right now we use File Merge/Pattern to import a SLDPRT file into a "template" file that has some standard tools and operations defined. When we do that we need to "Save As" and pick up the filename of the imported file because the imported file maintains the name of the file it was imported to, in this case "template.mcx-5". The machine group name and template name are then changed from "template-1" and "template-op10" respectively to match the name of the part file.
We are just looking to automate this process to save repeating this process for each part we program and to standardize to make sure the the mcx-5 files are going into a certain subdirectory of the directory where the SLDPRT file is.
AH!
Your "import" is really File-Pattern/Merge
This is a very important distinction!
The ImportFile command you're seeing the the VB Scripting is...
// Import ANY file type (IGES, STEP, DWG, DXF, Pro/E, Inventor, etc)
A File-Open command that allows for "opening" any type of supported file.
The File-Merge support in VB Script is the MergeMC command.
Note the 'MC' in the name. It will not merge "non-native" Mastercam file types.
Call Main
Sub main()
Dim strSLDPRTPath 	' -- The path portion of the input file
Dim strSLDPRTName 	' -- The filename portion of the input file
Dim strFullName		' -- The full path\filename of the input file
strSLDPRTPath = "C:\temp\SolidWorks Test Files\inch\"
strSLDPRTName = "Island Facing_INCH.SLDPRT"
strFullName = strSLDPRTPath & strSLDPRTName
' -- Import (load) this SLDPRT file into the current Mastercam session
Call ImportFile(strFullName) ' <- This will work with a .SLDPRT file type
' --  Merge a Mastercam file
Call MergeMC(strFullName) ' <- This will NOT work with a .SLDPRT file type
End Sub
Subject: Merge SLDPRT file into the active Mastercam database.
MergeSLDPRT2MCX AddOn
*The AddOn and the full C# source code is included in the attached MergeSLDPRT2MCX.zip
You can build (or alter and rebuild) the project using Microsoft Visual Studio.
You can even use the free Express version.
You may think that VB Script is easy (or easier) than C# or VB.NET
Well... maybe is you do a lot of VB Scripts.
But compare this NETHook code to the VB Scripting in the earlier posts.
*It's true that this AddOn does not do exactly the same thing, but the comparison is still valid.
This code in the MergeFile.cs does all of the real Merge/Save work ->
It is also saving the folder path so that it can recall it the next time it is run. (You can see that code in the Config.cs file)
       /// <summary>Merge a .SLDPRT file and save out the result as an .MCX-5 file.</summary>
       /// <remarks>Note that "failure" can just mean the user aborted.</remarks>
       /// <returns>On success, returns the full path/name of the new file, or string.Empty if failed.</returns>
       public string ProcessFile()
           // The "new" filename that we return to the caller.
           // Will be string.Empty if the process did not complete.
           string newFile = string.Empty;
           // Get the previously used folder path
           Config cfg = new Config();
           string initialInputFolder = cfg.InputFolder;
           // Check to be sure the this folder actually exists
           if (!Directory.Exists(initialInputFolder)) // If not..
               { initialInputFolder = string.Empty; } // Clear it.
           // The user selected input folder
           string folder = string.Empty;
           // Ask the user for the input file
           string filename = SelectFile(initialInputFolder);
           if (!string.IsNullOrEmpty(filename))
               bool promptToSaveCurrent = false;
               bool mergeFile = true;
               bool result = Mastercam.IO.FileManager.Open(promptToSaveCurrent, filename, mergeFile);
               if (result)
                   filename = Path.ChangeExtension(filename, ".MCX-5");
                   // Tell Mastercam to save it as...
                   if (Mastercam.IO.FileManager.SaveAs(filename))
                       { newFile = filename; } // success? - then get the new filename
                   // If the input folder has changed from what we had before...
                   // Save this path for later (to store off in the config)
                   folder = Path.GetDirectoryName(filename);
                   if (initialInputFolder != folder)
                       { cfg.InputFolder = folder; }
           return newFile;
What it does...
This AddOn prompts the user to select a SLDPRT file.
It then "merges" the data from that file into the current Mastercam database
and immediately saves the result as a Mastercam .MCX-5 file.
Example:
In -> C:\MyCadData\SolidWorks\MyDesign.SLDPRT
Out -> C:\MyCadData\SolidWorks\MyDesign.MCX-5
To install this Mastercam X5 NETHook AddOn.
Copy the MergeSLDPRT2MCX.DLL and MergeSLDPRT2MCX.FR files from the "Release DLL" folder to your Mastercam CHooks folder.
This is usually ->
C:\Program Files\mcamx5\CHooks
-or-
C:\Program Files (x86)\mcamx5\CHooks
After you restart Mastercam, there will be a new command icon available in the (main menu)
Settings, Customize, Category = File
You can add this command icon to a toolbar and/or map the command to a keystroke.
Or you can always run the AddOn "manually" via the main menu -
Setting - Run User Application and selecting the MergeSLDPRT2MCX.DLL
MergeSLDPRT2MCX.zip
               if (result)
           return newFile;
What it does...
Example:
This is usually ->
-or-
Thank-you. We will play around with that and see where we are at.
Again I appreciate all you help.
Hi Matt.
I do about the same as you describe as far as organizing the files in sub-directories, and same kind of procedure also as far as merging into template to keep using standard tool list & toolpaths. One problem I had is one of the guys overwrote on the template once so we had to clean it up. This comes from as you described, he merged the solidworks file into MCX template.
What if you go the other way around and ask you script to open the SLDPRT file and then Import/merge your template in? I say Import/Merge because a regular file Merge will call geometry and named levels table but it won't call toolpaths nor WCS's you have created, you have to actually import those.
I hope it helps, but I'm feeling you might be done already with your project :)
Hi Matt.
I am still looking at different ways that this goal can be achieved. I appreciate your input. I didnt think of doing it the other way around. Does it give you the same end result?
Actually, I was just testing Roger's addon and from what i can see, it does fine as far as getting rid of the overwriting on the template issue, but it doesn't save to a separate sub-directory as I understood you wanted.
So at this point is the users call whether you want to open your SLDPRT file 1st and then apply a template or open your template and then call a SLDPRT file to apply it to as this is the way Roger's Add on works.
We would normally save to a sub-directory.
Eg.
D:\RP\2011\RPC-11-00768
to
D:\RP\2011\RPC-11-00768\RPC Reference Files
However dragging the file afterwards is easy. It would be neat if it could do that as well tho.
How you you want to specify this "incremental" sub-directory path?
Is this something that changes often?
Meaning you would want/need to be able to specify it each time.
-or-
Is it something that only changes "every once in a while"?
It would be easy enough to add a Config option allowing the user to set this
and the AddOn would use that until you changed in its config.
You're finding out how important the details are when designing software! :D
-or-
I am indeed. I think a problem is solved and another arises. :)
We will always be adding the files to the sub-directory folder within the current directory named '\RPC Reference Files'
eg
C:\001 -To-
C:\001\RPC Reference Files
C:\002 -To-
C:\002\RPC Reference Files
or whatever our directory is.
The MergeSLDPRT2MCX AddOn has been updated.
It now outputs the "new" (MCX-5) file to a sub-folder under the .SLPRT input folder.
*This is optional and the sub-folder name is configurable.
See the ReadMe-First.txt file in the ZIP.
The updated ZIP is attached to the original posting above.
I cannot thank you enough Roger. It is a big help to what were trying to do.
Again, thanks.
Also thank you Manuel for helping to convey my ideas to Roger. :)
You have the source for the Project, so you can alter it, and re-build it using one of the free "Express" version of Visual Studio 2010.
Programming .NET (for NETHook) is not that difficult, as much of what you're doing is not directly Mastercam related. *Like the MergeSLDPRT2MCX project (done in C#) for example!*
I left the full "Mastercam.<namespace>. on each command that is a Mastercam NETHook method
and you can see that much of what MergeSLDPRT2MCX is doing is really just "plain old" Microsoft .NET
Which there is lots of help available on the Web.
Hi Roger. Thanks for doing this script. Matt L is our co-op student here this term and I had asked him if he could do something up like this as he said he had some VB programming experience. I'm glad you were able to help out with this (ie. do it for him :D:-) )
I've had script linker installed and now this chook is working as I had hope, saving the file in the proper directory. There are a couple of additions that would make it better if possible:
1. To save the chance of overwriting an existing file, could it check the directory that it is writing to see if a file by the same name already exists, and if so give us the option of over writing or not, or ask for a new filename? I'm sure this won't happen a lot but I could see it biting someone down the road.
2. My "template" that I use already has a machine group and a toolpath group with the name "template-1" and "template-op10" respectively. Could these be change to replace the word "template" with the filename of the MCX-5 file?
Thanks again for all your help on this. It should save me a good chunk of time and help to standardize where we all save our files.
Matt.
Thank-you. I do appreciate it.
However, to be fair, I wasn't looking for a freebie.
We were willing to pay our co-op student to do this, and he was asking for help on how to accomplish this on Emastercam which I recommended to him as a great resource, however he quickly determined it was beyond his capabilities and informed us of this.
I did also make this request to my re-seller and have yet to receive a response, possibly because they saw it being taken care of here.
Thanks again.
Enjoy your weekend.
Matt.
