browseforfolder and browseinfo function
Hi!
my first try to do a vbscript and I'm almost to where I'd like to.
Here is the project, I'd like to browse for a folder but I don't want to start from the desktop everytime. I'd like to start from a predefine folder but I would alos like to keep the possibility to go up some level. As I have been able so far to get the the starting folder I wanted but I can't go higher in the root...
Also if I could get a window format with the favorites (like the Win7 browser window for example) it would be great! (I've read there is something about the browseinfo function or command but I don't understand how to use it exactly)
So basically I'd like to either one of these 2 solutions:
- Start to a predefined folder but with the possibility to go up the root or even change completely the location.
or
- use a browser window like the mastercam one or the WinXP or Win7 browser with the favorites or special folder on the left side for quick selection.
Any help is appreciated
thanks in advance
PS Note that I'm calling this script from a post so that is why I write the selected folder into a text file.
André
here is the code I'm using right now.
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
' * This function will open the NC file for the nest
Dim strOutputFolder
Dim FSO, fsoMCX, fsoFiles, fsoNCFile
Set FSO = CreateObject("Scripting.FileSystemObject")
' -- Get MCX folder
strOutputFolder = BrowseForFolder("Select folder containing MCX files")
If FSO.FolderExists(strOutputFolder) Then
               Set fsoMCX = FSO.GetFolder(strOutputFolder)
               'strOutputFolder = BrowseForFolder("Select folder for NC Output files")
               'If FSO.FolderExists(strOutputFolder) Then
               '               Set fsoFiles = fsoMCX.Files
                               ' -- Iterate all files per folder
                '              For Each fsoMCX In fsoFiles
               ' -- Only looking for MCX files
    '          If Right(ucase(fsoMCX.Name), 3) =  "MCX" Then
               ' -- Open it
     '         Call NewMC(false)
      '        Call OpenMC(fsoMCX)
                                               ' -- Post it
                               'Call RunPostAll(strOutputFolder, false)
               'End If
               'Next
   'End If
   FSO = WriteFileText(strOutputFolder)
End If
' -- Clean up
Set fsoNCFile = Nothing
Set fsoFiles = Nothing
Set FSO = Nothing
End Sub
' Function Declaration
' Returns vbNullString if no folder selected
Function BrowseForFolder(strPrompt)
   On Error Resume Next
   Dim objShell, objFolder, intColonPos, objWshShell
   Dim FSO, varTemp
   Const sFilestart = "C:\Users\Andre Lapointe\Documents\my mcamx5\Mill\NC"
   ' -- Create our all important objects
   Set objWshShell = CreateObject("WScript.Shell")
   Set objShell = CreateObject("Shell.Application")
   Set objFolder = objShell.BrowseForFolder(&H0&, strPrompt, &H1&, sFilestart)
   ' -- Initialize to failure
   BrowseForFolder = vbNullString
   ' -- Did the user Cancel?
   If Not objFolder Is Nothing Then
       Select Case objFolder.Title
              ' -- Did the user select Desktop?
              Case "Desktop"
                  BrowseForFolder = objWshShell.SpecialFolders("Desktop")
              Case Else
                   ' -- Get the folder selected
                   varTemp = objFolder.ParentFolder.ParseName(objFolder.Title).Path
                   ' -- If the user does not select a folder or cancels out an error is raised
                   If Err Then
                      Select Case Err.Number
                             ' -- Probably root drive selected e.g. (C:)
                             Case 91, 424
                                   ' -- Check for Root
                                   intColonPos = InStr(objFolder.Title, ":")
                                   If intColonPos > 0 Then
                                      BrowseForFolder = Mid(objFolder.Title, intColonPos - 1, 2) & "\"
                                   End If
                              Case Else
                       End Select
                       Err.Clear
                   Else
                       ' -- If we get this far make sure the folder exists
                       ' -- selecting a network folder may result in an invalid folder
                       If FSO.FolderExists(varTemp) Then BrowseForFolder = varTemp
                   End If
        End Select
   End If
   ' -- Check for an error of any kind
   If Err Then
      ShowString "Error selecting folder: " & Err.Description, vbExclamation, "BrowseForFolder"
      Err.Clear
      Exit Function
    End If
' -- Clean up
Set objWshShell = Nothing
Set objShell = Nothing
Set objFolder = Nothing
Set FSO = Nothing
End Function
' WriteFileText - Used to write an item to a file in a folder.
' Parameters:
'   sFile - The file to read
' Returns:
'   A string containing the content of the file.
Function WriteFileText(sText)    'sFilepath --> path du fichier texte   sText---> path que je veux
   Dim objFSO 'As FileSystemObject
   Dim objTextFile 'As Object
   Const ForReading = 1
   Const ForWriting = 2
   Const ForAppending = 8
   Const sFilePath = "C:\test.txt"
   Set objFSO = CreateObject("Scripting.FileSystemObject")
   Set objTextFile = objFSO.CreateTextFile(sFilePath, True)
   ' Write a line.
   objTextFile.Write (sText)
   objTextFile.Close
   'objTextFile.Close
End Function
I don't believe this is possible with VB Script.
The folder path you supply as the final parameter is the "root" folder,
so you cannot navigate above that - *using VBScript.
Ref: Shell.BrowseForFolder method
or
Where in Mastercam do you see the dialog your describe used when selecting a folder?
It sound like you are describing the File Select/Open dialog.
Why not use a NETHook? (Either C# or VB)
You can find MUCH more useful and consistent help info for these than the myriad ways of VBScript. Even Microsoft has basically abandoned VBScript "as-is" for PowerShell. (Which is very powerful and very confusing for getting started or for something you use every once in awhile).
You can use the free Visual Studio "Express" versions for creating NETHooks.
Here is a VB.NET function that does the std FolderBrowserDialog, but unlike the VBScript version, the SelectedPath is preset with the desired initial folder and the user can browse above this folder (or actually anywhere).
*I prefer C# and I think you'll find more how-to help out on the Web for it vs. VB.
Either way it is simple to convert between the two. Which is exactly what I did here from for this code C# -> VB
''' <summary>Display the 'Browse for Folder' Dialog.</summary>
''' <param name="initialFolder">The default starting folder path.</param>
''' <returns>The selected Folder or String.Empty if user aborted.</returns>
Public Shared Function SelectFolder(initialFolder As String) As String
Dim folder As String = String.Empty
Dim fbd As New FolderBrowserDialog()
If Directory.Exists(initialFolder) Then
	fbd.SelectedPath = initialFolder
End If
fbd.ShowNewFolderButton = True
fbd.Description = "Select output subfolder..."
If fbd.ShowDialog() = DialogResult.OK Then
	folder = fbd.SelectedPath
End If
Return folder
End Function
Thanks Roger,
The main reason why I wanted the VBS instead of the Nethook is because I didn't want to support the Nethook at every new release of Mastercam.
The VBS allow me to just copy and pste to the new folder, I put it in the post folder so I don't even have to change the path in the post for it to work in a more recent version.
As for the window I was refering to in Mastercam, yes it is the file select/open dialog box.
Thanks for looking at it I really appreciate it!
I guess I'll discuss with the customer to see what he prefers, starting on the desktop or in the sub folder with no possibility to go higher in the root.
Thanks again.
I understand, but if you're going to give them the VBScript source (not that you have a choice)
you can certainly give then the .NET project. Then they can rebuild it (if needed) using a free Express version of Visual Studio.
Well, how about SEEDING the BrowseForFolder dialog with a folder one or more folders UP from the folder
you (probably) want the user to select?
Function ParentFolder(strBaseFolder)
Dim filesys
Set filesys = CreateObject("Scripting.FileSystemObject")
ParentFolder= filesys.GetParentFolderName(strBaseFolder)
End Function
