Post help.
Good morning all,
I am working on Custom drill cycle for Probe (use Mpmaster for base).
This is what i get so far and i need help to get it right.
Code
(PROBE Z)
N41 (6MM PROBE)
G0 G17 G40 G80 G90 T41
G0 G28 G91 Z0
G90
M06
(MAX - Z3.)
(MIN - Z-.25)
G00 G17 G90 G54 X.9262 Y2.3656
G00 Z3.<---------------------------------I need to move this line up
G94
G65P9810 X.9262 Y2.3656 F120.
G65P9810 Z.1
G65P9811 Z0. S1. (PROBE SURFACE SET Z)
G65P9810 Z3.
X3. Y2. <----------------------------------Take this line out.
G65 P9810 X3. Y2. F120.
G65 P9810 Z-.25
G65 P9814 D0.5 S1. (PROBE BOSS/BORE)
G65 P9810 Z.1
M05
G0 G91 G28 Z0.
G28 Y0.
G90
M127 (CONVEYOR OFF)
and here is what i need
Code
(PROBE Z)
N41 (6MM PROBE)
G0 G28 G91 Z0
G90
M06
(MAX - Z3.)
(MIN - Z-.25)
G94
G65P9810 Z.1
G65P9810 Z3.
G65 P9810 Z-.25
G65 P9810 Z.1
M05
G0 G91 G28 Z0.
G28 Y0.
G90
M127 (CONVEYOR OFF)
Thanks in advance
A couple of questions. You said you wanted to move the Z3 up in code, but the desired output does not have this move, do you just want the Z3 line removed?
Also I'm not sure how you've set up the probing cycles in the post. In mastercam I'm assuming there are two separate operations used to produce this code (since there are two different probing cycles used). Can you please confirm?
I am really sorry ( this is what happen when i try to manually edit my code which i am doing in my shop right now!!!)
Yes, there are two separate probe cycle used and It should be read:
Code
(PROBE Z)
N41 (6MM PROBE)
G0 G28 G91 Z0
G90
M06
(MAX - Z3.)
(MIN - Z-.25)
G00 G17 G90 G54 X.9262 Y2.3656 Z3. <------------------------------ move Z3.to here
G94
G65P9810 Z.1
G65P9810 Z3.
G65 P9810 Z-.25
G65 P9810 Z.1
M05
G0 G91 G28 Z0.
G28 Y0.
G90
M127 (CONVEYOR OFF)
Here is how i set this up.
Code
#Use this postblock to customize drilling cycles 8 - 19
pdrlcommonb
probeflg = 0
dwell2 = dwell$
dwell1 = dwell$
offupdate1 = peckclr$
offupdate2 = retr$
if offupdate2 > 0 & offupdate1 = 0,
offupdate2 = offupdate2 + 100
if drillcyc$ = 8,
"G65 P9810", pfxout, pfyout, "F120.", e$
zbossdep = refht_a
"G65 P9810", [if peck1$=0, zbossdep], [if peck1$ = 1, z$], e$
"G65 P9814", *dwell1, [if peck1$ = 0, pfzout], [if offupdate1 > 0 & offupdate2 = 0, *offupdate1],
[if offupdate2 > 0 & offupdate1 = 0, *offupdate2], "(PROBE BOSS/BORE)", e$
z$ = refht_a
"G65 P9810", *z$, e$
if retr$ > 48, result = mprint(serror), exitpost$
if retr$ < 0, result = mprint(serror), exitpost$
if offupdate1 > 0 & offupdate2 > 0, result = mprint(serror), exitpost$
if drillcyc$ = 11,
z$ = refht_a
"G65P9810", pfxout, pfyout, "F120.", e$
"G65P9810", pxout, pyout, z$, e$
"G65P9811", pfzout, [if offupdate1 > 0 & offupdate2 = 0, *offupdate1],
[if offupdate2 > 0 & offupdate1 = 0, *offupdate2], "(PROBE SURFACE SET Z)", e$
z$ = initht$, e$
"G65P9810", *z$, e$
Thanks.
