c-axis filter
4thaxis
I am green to c-axis programming. I can get mastercam to do what I need to do with no problems but when I post the operation that is where I get a result that I am not happy with. I am going to piece in a part of a prgram that I posted for milling a 1.120 hex using a 3/8 end mill. All of this code is just for milling (1) side of the hex. Is there any way to change a filter setting or something so it does not break up 1 move into pieces? In my mind to mill a flat on a hex all I need is an "x" and a "c" value for each side.
Here is the NC code for milling just 1 side of a hex.
G0 G54 X1.8473 Z.1
C6.508
G97 S2500 M52
G98 G1 Z-.2125 F20.
X1.7474 C6.67 F64.95
G41 X1.6476 C6.856
X1.645 C3.637 F1391.56
X1.6449 C-3.641
X1.6476 C-6.856
X1.6053 C-10.688 F1313.43
X1.571 C-14.658 F1377.56
X1.5447 C-18.743 F1431.67
X1.5267 C-22.914 F1473.28
X1.5169 C-27.138 F1500.33
X1.5155 C-31.381 F1511.44
X1.5223 C-35.607
X1.5374 C-39.781 F1484.56
X1.5606 C-43.872 F1448.13
X1.5917 C-47.85 F1398.67
X1.618 C-50.545 F1348.62
X1.6476 C-53.144 F1303.19
X1.645 C-56.363 F1391.56
Also are all the feedrates needed also?
Thanks in advance,
Brian
+1^ on the polar cord. (G112). it looks like you might be driving on a slpine and not lines/arcs.
with our hardinge msy i prg. to the edge of the tool with a long lead in line. set my feed rate for the chip load i want
then the machine figures out the "C" axis feed rates to keep the chip load i want.
Brian,
I believe the feed as posted is in degrees per minute so to keep your programmed feed rate mastercam converts feed as needed.
I would use c-axis tool path/face contour to define your cutting information then go into misc values and under integers change Misc integer MI4 to a -1 ( Mill Cyc G107/G112 [0=OFF,1/-1=ON) that will allow the program to post using polar notching as stated above. This will give you more familiar code and feed rates.
Hope this helps.
