need help when using G17
need help when using G17 XY axis on lathe, the mastercam output coordinates are obtained by diameter, but it does not suit me, I need to output code by radius, how to fix it?
I need it for Siemens 840C with c axis, which has xy coordinates set by radius.
turning must be by diameter
any idea???
I use GENERIC FANUC AXIS LATHE C-post with some changes that can work with Siemens 840C, I tried to change
dia_mult: 2 # Multiplier for output on X axis (Neg. switches sign of X)
milling output codes look good (I did not tried it on the machine)
but turning must remain at diameter
Then you must place a conditional statement that chages the dia_mult from 2 to 1 and back to 2 after milling ops are complete, something along the lines of:
if cuttype = 4, dia_mult = 1
And towards the end of the mill tool change, set it back like this:
dia_mult = prv_dia_mult
What are you trying to do a C-axis contour or a Cross conntour. I fired up my debugger and used the same post as you and got a good output.
