Modifying a Haas 4 axis post?
CJH
Hey guys,
I have a question that I need help with. I want ot know if there is a way to modify a Haas 4 axis post to output the A postion to only 3 decimal places? Up until now we have manily been doing indexing with our rotary. So we would get the output for the specific angle rotation needed without the trailing decilmal places. Now I have a project where I have to engrave on a cylinder, and the output is going to 4 places and our mill cointrol only reads to 3 places on the A axis. any help you can give would be appreciated.
Chris
You can use the debugger to find the variable that outputs the a axis positioin, then change the format statement to decimal absolute, 3 place.
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6	 #Decimal, absolute, 7 place, default for initialize (
fs2 2 0.4 0.3	 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d	#Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0	 #Integer, not leading
fs2 5 2 0 2 0l	#Integer, force two leading
fs2 6 3 0 3 0l	#Integer, force three leading
fs2 7 4 0 4 0l	#Integer, force four leading
fs2 9 0.1 0.1	 #Decimal, absolute, 1 place
fs2 10 0.2 0.2	 #Decimal, absolute, 2 place
fs2 11 0.3 0.3	 #Decimal, absolute, 3 place
fs2 12 0.4 0.4	 #Decimal, absolute, 4 place
fs2 13 0.5 0.5	 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d	#Decimal, delta, 3 place
fs2 15 0.2 0.1	 #Decimal, absolute, 2/1 place
fs2 16 0 4 0 3t	#No decimal, absolute, 4 trailing
#Default english/metric feed format statements
fs2 17 0.2 0.1	 #Decimal, absolute, 2/1 place
fs2 18 0.4 0.3	 #Decimal, absolute, 4/3 place
fs2 19 0.5 0.4	 #Decimal, absolute, 5/4 place
fs2 20 1 0 1 0n	#Integer, forced output
fs2 25 1.4 1.3lt #Decimal, absolute, 4/3 trailing
# These formats used for 'Date' & 'Time'
fs2 21 2.2 2.2lt	#Decimal, force two leading & two trailing (time2)
fs2 22 2 0 2 0t	 #Integer, force trailing				 (hour)
fs2 23 0 2 0 2lt	#Integer, force leading & trailing		 (min)
fs2 26 0.0 0.0	 #decimal														 g&l speed
# This format statement is used for sequence number output
# Number of places output is determined by value for "Increment Sequence Number" in CD
# Max depth to the right of the decimal point is set in the fs statement below
fs2 24 0^7 0^7	 #Decimal, 7 place, omit decimal if integer value
# Toolchange / NC output Variable Formats
fmt	 4 partflip #
fmt T 7 toolno	 #Tool number
fmt T 5 gtoolno	 #Tool number
In the snippet above, fs2 11 (format statement 11) is what you want.
The last 3 lines above show some variables being formatted, using 4, 7, and 5....
My guess for the output variable you are looking for is "cabs" and "cinc" (absolute output, and incremental output)
I have attached simple instructions to enable and use the debugger.
debugger instructions.doc
