Tool Type Determination
Our machine is currently only measuring a flat endmill via the posted code. The call to this macro is P9623. I am trying to get the post to pull the tool type (20004 parameter) put it into my user defined variable and use a string selector to output the corresponding tool measuring macro (P9623 etc.). I do not get the correct output out of the string selector. The value going in is at the moment a type_tool of 10, but I am not getting anything out. Until it is solidly decided what each tool type's macro is I have placed their names in the string for now. It seems like it is stopping at the string selector. Anyone know what I am doing wrong?
Parameter page from Reference Guide:
20004:Tool definition: tool parameters
20004
1 2 3 4 5 6 7 8 9 10 11 12 16 14 15 19 17 18
  1. tool number
  2. tool type:
1 = center drill
2 = spot drill
10 = end mill - flat
pparameter$ #Read operation parameters
if prmcode$ = 20004, type_tool = rparsngl(sparameter$, 2)
type_tool : 0
#tool type for tool length measurement
tp00 : "CENTER DRILL"
tp01 : "SPOT DRILL"
tp02 : "DRILL"
tp03 : "RIGHT HAND TAP"
tp04 : "LEFT HAND TAP"
tp05 : "REAMER"
tp06 : "BORING BAR"
tp07 : "COUNTER BAR"
tp08 : "COUNTER SINK"
tp09 : "END MILL - FLAT" eventually will be "P9623"
tp10 : "END MILL - SPHERICAL"
tp11 : "CHAMFER MILL"
tp12 : "FACE MILL"
tp13 : "SLOT MILL"
tp14 : "RADIUS MILL"
tp15 : "DOVETAIL MILL"
tp16 : "TAPERED MILL"
tp17 : "LOLLIPOP MILL"
tp18 : "BULLNOSE"
stype_tool : ""
fstrsel tp00 type_tool stype_tool 19 -1
The variables in the string select table must be defined as strings.
Try this:
stp00 : "CENTER DRILL"
stp01 : "SPOT DRILL"
stp02 : "DRILL"
stp03 : "RIGHT HAND TAP"
stp04 : "LEFT HAND TAP"
stp05 : "REAMER"
stp06 : "BORING BAR"
stp07 : "COUNTER BAR"
stp08 : "COUNTER SINK"
stp09 : "END MILL - FLAT" eventually will be "P9623"
stp10 : "END MILL - SPHERICAL"
stp11 : "CHAMFER MILL"
stp12 : "FACE MILL"
stp13 : "SLOT MILL"
stp14 : "RADIUS MILL"
stp15 : "DOVETAIL MILL"
stp16 : "TAPERED MILL"
stp17 : "LOLLIPOP MILL"
stp18 : "BULLNOSE"
stype_tool : ""
fstrsel stp00 type_tool stype_tool 19 -1
You can also use the variable tool_typ$ if you want so you do not have to read the parameter number.
Is the first tool used a flat endmill?
There is an issue with the one string variable declaration.
stp09 : "END MILL - FLAT" eventually will be "P9623" <-- There are too many quotation marks and characters outside the quotation marks.
Change to something like this:
stp09 : "END MILL - FLAT eventually will be P9623"
OR
stp09 : "END MILL - FLAT" #eventually will be "P9623"
