Add Comp Macro post?
Merry Christmas to all,
I want to add a comp macro to our post so that we will not forget to enter a comp value in the register when needed, we program online so if we forget we make BIG holes or small Blocks.
the code lookes like:
N4T4M6(2" INCH COMP= RAD.)
Y_[1]=$TC_DP6[$TC_MPP6[9998,1],1]*1
IF(Y_[1]>1.01)GOTO N5555 tool radius +.01
IF(Y_[1]<.99)GOTO N5555 tool radius -.01
G49G53Z0.Y0.X-18.M9
GOTO N6666
N5555SETAL(65000)
M00;CUT COMP ERROR
N6666
I want this tied to G41 /G42 so it is only output on tools with comp
I believe I can Force All the code and the ±.01 , if I knew where in the post "Comp" and "Tool Radius" is?
Thanks Forum
Hi there.
In your post initialize this variable in case it is not:
fmt 2 tlrad$ #tool radius format
Then at "ptlchg_com" , after your M06 add this lines:
spaces$ = 0
pbld, "CHECK_RAD(", *tlrad$, ")",e$
spaces$ = 1
On machine create this user cycle called "CHECK_RAD" :
PROC CHECK_RAD(REAL TOOL_RAD, REAL _TOL)
DEF REAL FACTOR_SCALING
DEF REAL ACTUAL_TOOL_NR
DEF REAL _TOL_UP
DEF REAL _TOL_DOWN
IF $MN_SCALING_SYSTEM_IS_METRIC==0
FACTOR_SCALING=$MN_SCALING_VALUE_INCH
ELSE
FACTOR_SCALING=1
ENDIF
ACTUAL_TOOL_NR=$TC_DP6[$TC_MPP6[9998,1],1] ;CAPTURE TOOL RAD IN SPINDLE
IF _TOL==0
_TOL=0.254/FACTOR_SCALING ;DEFAULT VALUE FOR TOLERANCE IN MM
ENDIF
_TOL_UP=TOOL_RAD+_TOL
_TOL_DOWN=TOOL_RAD-_TOL
IF (ACTUAL_TOOL_NR>_TOL_UP)OR(ACTUAL_TOOL_NR<_TOL_DOWN) GOTOF _ALLARM
_END: M17
_ALLARM:SETAL(65000)
M00 ;CUTTER COMP ERROR
What will happen:
after each tool change your post will add a line
CHECK_RAD(tool_rad) where tool_rad= your active tool radius
the cycle wich I made 4U will check that your posted value for that tool and the value of the actual tool in spindle differ with a default value(0.254mm /see the custom cycle.)
Also you can manually modify the tolerance value by adding the new value after the tool rad like this
CHECK_RAD(1,0.02)
1=tool rad to be checked
0.02= new tolerance/in current measuring system /in or mm G700 OR G710
Let me know if U have some difficulties
Edited by Griveous74
