Okuma MC-4VB tool change variable for active tool
Hello,
I am working on a post for a Okuma MC-4VB vertical 50 taper mill. I started with a MPmaster post. I need it to have the following code before every tool change. How do I do this in the post..
Needs to look like this..
(prog)
N2 IF [VATOL EQ 10] N4 <---------------- I need the [VATOL EQ (the current tool nuber)] N4 --------------- to post before every tool change...
N3 T10 M6
N4 S---- M3
In my MC-4Vb, VATOL is the system variable for active tool. Line N2 is a conditional that will jump to N4 if the tool 10 is already there, if not, it will proceed to N3 and change the tool
I'm not tested this, but should work. :)
Very first thing: Make a backup of your post! :)
Define a variable (in start of post) to hold actual T number for VATOL
# Set variable for VATOL
oku_VATOL : 0 #VATOL
Find this section in ptlchg_com postblock.
if stagetool >= zero,
 if omitseq$ = 1 & tseqno > 0,
	 if tseqno = 2, n$ = t$
	 pbld, *n$, *t$, "M06", ptoolcomm, e$
 else, pbld, n$, *t$, "M06", ptoolcomm, e$
Change it:
("N4" will be an empty line)
    oku_VATOL = t$
        "N2 IF [VATOL EQ ", *oku_VATOL, "] N4", e$
        "N4", e$
 else,
        "N4", e$
If you need to follow the different "N" line numbers at toolchanges, thats a bit different story, but not impossible.
Let me think.... Hmm... Yes, I think you have to, beacuse it's an OKUMA... :S
...but give a try for this first.
Is it an older controll? OSP5000?
This is what I did, I'm sure there is a better way. I would like to know what it is. I only use line numbers on the first few lines of a toolchange.
I created this Variable here,
# Toolchange / NC output Variable Formats
fmt 4 okuma_skip_toolnumber
I added / modified the code under this part of the post
#Start of file for non-zero tool number
spaces$=0
okuma_skip_toolnumber = t$
pbld, n$, " IF [VATOL EQ ", *okuma_skip_toolnumber,"] ",
n$ = n$ + seqinc$,
n$ = n$ + seqinc$,
*n$, " (SPINDLE TOOL CHECK)", e$
spaces$=sav_spc
n$ = n$ - seqinc$
n$ = n$ - seqinc$
pbld, n$, *t$, "M6", e$
pbld, *n$,[if nextdc$ <> 7, *speed, *spindle], pgear, strcantext, "(SPINDLE TOOL JUMP)", e$
output looks like this..
N1 IF [VATOL EQ 104] N3 (SPINDLE TOOL CHECK)
N2 T104 M6
N3 S1055 M3 (SPINDLE TOOL JUMP)
spaces$=0
n$ = n$ + seqinc$,
n$ = n$ + seqinc$,
spaces$=sav_spc
n$ = n$ - seqinc$
n$ = n$ - seqinc$
N2 T104 M6
Ok I think I might be changing it in th wrong place.. It posted out fine for the first tool but the next tool there is no M6 or anything.. Below is where I put the changes in the mpmaster post
N100 G00 G17 G20 G40 G80 G53 G90
N110 G91 G30 P2.0 Z0.
N120 IF [VATOL EQ 1] N140 (SPINDLE TOOL CHECK) <------------------- this looks great --------------->
N130 T1 M6
N140 S2800 M03 (SPINDLE TOOL JUMP)
N150 (MAX - Z4.)
N160 (MIN - Z-1.025)
N170 M08
N180 G00 G17 G90 G54 X8.665 Y.5 S2800 M03
N190 G56 H4 Z4. T12
N200 Z.2
N210 G94 G01 Z-1.025 F120.
N220 G41 D4 Y0. F80.
N230 Y-2.4375
N240 G02 X8.25 Y-2.8525 I-.415 J0.
N250 G03 X2.8525 Y-8.25 I0. J-5.3975
N260 G02 X2.4375 Y-8.665 I-.415 J0.
N270 G01 X0.
N280 G40 X-.5
N290 G00 Z2.975
N300 X8.635 Y.5
N310 Z.2
N320 G01 Z-1.025 F120.
N330 G41 D4 Y0. F80.
N340 Y-2.4375
N350 G02 X8.25 Y-2.8225 I-.385 J0.
N360 G03 X2.8225 Y-8.25 I0. J-5.4275
N370 G02 X2.4375 Y-8.635 I-.385 J0.
N380 G01 X0.
N390 G40 X-.5
N400 G00 Z4.
N410 (FINISH MILLS OUTSIDE PROFILE WITH 3/4 ENDMILL)
N420 X8.625 Y.5
N430 Z.2
N440 G01 Z-1.025 F120.
N450 G41 D4 Y0. F40.
N460 Y-2.4375
N470 G02 X8.25 Y-2.8125 I-.375 J0.
N480 G03 X2.8125 Y-8.25 I0. J-5.4375
N490 G02 X2.4375 Y-8.625 I-.375 J0.
N500 G01 X0.
N510 G40 X-.5
N520 G00 Z4.
N530 M09
N540 M05
N550 G91 G30 P2.0 Z0.
N560 M01 <------------------------ not tool change after this line --------------------------->
N570 (MAX - Z4.)
N580 (MIN - Z-1.025)
N590 M08
N600 G00 G17 G90 G54 X8.75 Y-2.5925 S550 M03
N610 G56 H12 Z4. T1 <-------------------------- There is a height offset for t12 ------------------>
N620 (ROUGH AND FINISH MILLS WITH 15 DEG TAPER E.M.)
N630 Z.2
N640 G94 G01 Z-1.025 F125.
N650 G41 D12 X8.25 F5.
N660 G03 X2.5925 Y-8.25 I0. J-5.6575
N670 G01 G40 Y-8.75
N680 G00 Z2.975
N690 X8.75 Y-2.5625
N700 Z.2
N710 G01 Z-1.025 F125.
N720 G41 D12 X8.25 F5.
N730 G03 X2.5625 Y-8.25 I0. J-5.6875
N740 G01 G40 Y-8.75
N750 G00 Z4.
This is where i changed the mpmaster post
ptlchg_com #Tool change common blocks
if force_output | sof,
result = force(ipr_type,ipr_type)
result = force(absinc$,absinc$)
result = force(plane$,plane$)
pcom_moveb
pcheckaxis #Check for valid rotary axis
c_mmlt$ #Multiple tool subprogram call
#ptoolcomment
if sof & scomm_sav <> snull,
spaces$=0 <------------------------------------------------------------ From here to ------------------------------------->
n$ = n$ + seqinc$,
n$ = n$ + seqinc$,
spaces$=sav_spc
n$ = n$ - seqinc$
n$ = n$ - seqinc$
pbld, *n$,[if nextdc$ <> 7, *speed, *spindle], pgear, strcantext, "(SPINDLE TOOL JUMP)", e$ <------------------------------------ Here ------------------------------>
spaces$=0
if output_z = yes$,
preadbuf5
if (opcode$ > 0 & opcode$ < 16) | opcode$ = 19,
n$, pspc, scomm_str, "MAX - ", *max_depth, scomm_end, e$
n$, pspc, scomm_str, "MIN - ", *min_depth, scomm_end, e$
spaces$=sav_spc
pstock
if plane$ < 0 | opcode$ = 3 | opcode$ = 16, plane$ = 0
sav_absinc = absinc$
if wcstype > one, absinc$ = zero
pindex
if safe_index,
And here
fmt "T" 4 t$ #Tool No
fmt "T" 4 first_tool$ #First Tool Used
fmt "T" 4 next_tool$ #Next Tool Used
fmt "D" 4 tloffno$ #Diameter Offset No
fmt "H" 4 tlngno$ #Length Offset No
fmt "G" 4 g_wcs #WCS G address
fmt "P" 4 p_wcs #WCS P address
fmt "S" 4 speed #Spindle Speed
fmt "M" 4 gear #Gear range
fmt 4 okuma_skip_toolnumber <----------------------added this line here --------------------------->
  • 2 weeks later...
