Mazak gear change in post
Darin
Hello,
We have a Mazak horizontal that has three speeds for RPM.. I need the post to post a M37,M38 or M39 at certain RPM's.. How do I make the post do this..
Needs to before the M03 or on same line..
M37 is 0 to 535 RPM
M38 is 536 to 1650 RPM
M39 is 1651 to max which is 5000 RPM
Darin,
In the MpMaster mill post there is a variable called "use_gear"
use_gear : 0 #Output gear selection code, 0=no, 1=yes
then you can adjust the RPM range in this look-up table
# Define the gear selection code
flktbl 1 3 #Lookup table definition - table no. - no. entries
40 0 #Low gear range
41 400 #Med gear range
42 2250 #Hi gear range
Darin,
Thank you.. Worked awesome...
