post question on helix_tol
perfecseal mankato
this is a new pre-defined variable in
ver 9.1sp1. the question I have is
has anyone used this variable yet.
We have all fadal machining centers here
and they sometimes die on helical arcs.
This may be the solution, if I understand the variable correctly.
I understand it as a tolerance in the plane perpendicalar to the arc requiring a specified amount of movement to output the helical arc.
Any input would be greatfully appreciated.
Thanks.
You are correct. That is what it is.
The motion distance in the plane perpindicular (the Z axis if doing a helix in the XY plane) that is required for the move to be considered a 'valid' helix move.
On the helix motions where your Fadal dies, what is the motion distance in the perpindicular axis ?
If it is too small, the machine may not like that.
That is the reason for the HELIX_TOL post varible.
Say that the Z axis is only going to move 0.0005" on a helix motion block. If HELIX_TOL is set to 0.001, the post should not output that helix move, but output just a std. arc motion on that block, since the Z motion is less than HELIX_TOL
