Drill Recommendation
Im getting ready to start a job and I need a drill recommendation. I have to drill a total of (3,636) 9mm holes and (2,432) 6.6mm holes through some structural channel. Each part only gets 6-8 holes. Im using some older machines so my rapid movements are hindering my cycle times. Its just structural channel so Im limited on improvements I can make in my setups to improve cycle time. Could I benefit from a high performance drill? Im only punching a hole through about 3/16" of material. Would it be worth it?
This almost sounds like a hydraulic press job rather than drilling.
We've got an Iron worker but not the tooling. The holes go down the side of the channel and I don't have the right punch and die. Also, after talking to a couple of my machinists and welders they believe it would be hard to hold the location required.
Look at the Dormer A520 ADX HSS TiN Stub Drills. (4XD). They are a very cheap performance drill. We get the 1/4" ones for $22 each and in A36 we get around 750 holes running them 1900 rpm @18 ipm with no peck and with the split point design there is no need for a spot to start the drills. If you call there tech Marty at 1-888-336-7637 he will be more then happy to help you out or suggest a better alternative for your needs.
