O/T Excel
George_Gerhard
Well,
Moldplus made a C-Hook that would do EXACTLY that but they stopped development on it for some reason. I used it for a while until the time ran out on it.
Perhaps Mick at CNC has a VB Script that can accomplish the same thing.
Here's the examples from the VB directory. One shows how to create lines via points in excell. The other shows how to create geometry and apply toolpaths to it.
'// Author: PCR
'// Date: 7/26/02
'// File Name: Excel2.vbs
'// Description: Read XY points from an Excel file and make a set of lines connecting them
'// Comments: Added header, comments etc. 2/5/2003 3:23:00 PM Mick George
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim strFileName
Dim bRet
Dim objLine, intCounter
Dim strCellA, strCellB, strCellC, intRow
Dim dblPointX, dblPointY, dblPointZ
Dim strXLS
' -- Test for a current drawing
Call ClearScreen
' -- Pre-select file
strXLS = GetPathOfThisScript & "xyz.xls"
' -- Prompt for a file
bRet = AskForFileName(strXLS, "r", strFileName)
' -- See if we have a valid file
If bRet Then
' -- Open the file
bRet = OpenExcelFile(strFileName)
End If
' -- Success?
If bRet Then
' -- Create a new Line class object
Set objLine = New McLn
strCellA = "a1"
strCellB = "b1"
strCellC = "c1"
With objLine
.x1 = 0
.x2 = 0
.y1 = 0
.y2 = 0
.z1 = 0
.z2 = 0
rem get the 1st point
bRet = AskExcelValue(strCellA, dblPointX)
If bRet Then
.x1 = dblPointX
End If
rem get the 2nd point
bRet = AskExcelValue(strCellB, dblPointY)
' -- Success?
If bRet Then .y1 = dblPointY - 2
rem get the 3rd point
bRet = AskExcelValue(strCellA, dblPointZ)
' -- Success?
If bRet Then .z1 = dblPointZ
rem loop through the points
intCounter = 2
Do
strCellA = "a"
strCellB = "b"
strCellC = "c"
intRow = CStr(intCounter)
' -- Get the next row for each cell
strCellA = strCellA & intRow
strCellB = strCellB & intRow
strCellC = strCellC & intRow
' -- Success?
If bRet Then
' -- Success?
If bRet Then dblPointY = dblPointY -2
End If
' -- Success?
If bRet Then bRet = AskExcelValue(strCellC, dblPointZ)
' -- Success?
If bRet Then
.x2 = dblPointX
.y2 = dblPointY
.z2 = dblPointZ
Call lineSub(objLine)
End If
' -- Store the row number
intCounter = intCounter + 1
Loop While bRet <> 0
CloseExcelFile()
' -- Zoom All
RepaintScreen True
End With
End If
' -- Clean up
Set objLine = Nothing
End Sub
' Sub Declaration
Sub lineSub (objLine)
Dim intRet
intRet = CreateLine(objLine, mcCONSTRUCTION_COLOR_CURRENT, mcCONSTRUCTION_LEVEL_CURRENT)
With objLine
.x1 = .x2
.y1 = .y2
.z1 = .z2
End With
End Sub
' Sub Declaration
Sub ClearScreen
Dim bRet
Dim strMsg
' -- Is there a drawing?
bRet = ChainAll(False,False,mcCHAIN_ALL_NUMBERED_LEVELS, mcCHAIN_ALL_NAMED_LEVELS)
' -- Ask user to clear screen
If bRet Then
strMsg = "Clear current drawing?"
' -- Ok?
bRet = askYesNo(strMsg)
' -- If so clear ot
If bRet Then Call NewMC(False)
End If
End Sub
'// Author: Mick George [email protected]
'// Date: 10/02/2003 02:11 PM
'// File Name: Make Cabinet Part.vbs
'// Description: Creates a simple cabinet part.
'// Comments:
'/////////////// My CONSTANTS //////////////////
Public Const DEF_CENTERED = " "
Public Const DEF_TITLE = "Mastercam"
Public Const DEF_PANEL_LEVEL = 2
Public Const DEF_DADO_LEVEL = 3
Public Const DEF_ARC_LEVEL = 4
' -- Kick off script
Call Main()
' Sub Declaration
Sub Main()
Call ResetAll
' -- Create the dowel holes first
Call CreateHoles
' -- Now create all internal dado routes
Call CreateDado
' -- Create the outline
Call CreateOutline
' -- Fit screen
Call RepaintScreen(True)
End Sub
' Sub Declaration
Sub ResetAll()
' -- Clear screen
Call NewMC(False)
' -- Fit screen
' -- Clear prompt area
Call ClearPromptLines
End Sub
' Sub Declaration
Sub CreateHoles
Dim CHoles
Dim intRet
Dim intRow
Dim intCol
' -- Create a new instance of a Mastercam Arc class object
Set CHoles = New McAr
With CHoles
.Z = 0
.R = .0635 ' -- 5mm
.SA = 0
.SW = 360
' ### Shelf holes ###
For intCol = 1 To 12 Step 6 ' -- Create two columns 6" apart
For intRow = 2 To 7 ' -- Create 6 holes 5mm dia * 32mm apart
.Y = (1.2598 * intRow)
.X = intCol
' -- Create the line
intRet = CreateArc(CHoles, mcCONSTRUCTION_COLOR_CURRENT, DEF_ARC_LEVEL)
Next
Next
End With
' -- Clean Up
Set CHoles = Nothing
End Sub
' Sub Declaration
Sub CreateDado
Dim CLine
Dim intRet
' -- Create a new instance of a Mastercam Line class object
' -- NOTE: - Use CreateRectangle in place of CreatLine
Set CLine = New McLn
With CLine
' ### Bottom Dado ###
' -- Assign the point co-ords
.X1 = .250
.Y1 = .250
.Z1 = 0
.X2 = .250
.Y2 = .500
.Z2 = 0
intRet = CreateLine(CLine, mcCONSTRUCTION_COLOR_CURRENT, DEF_DADO_LEVEL)
.X1 = .250
.Y1 = .500
.Z1 = 0
.X2 = 7.5
.Y2 = .500
.Z2 = 0
.X1 = 7.50
.Y1 = .500
.Z1 = 0
.X2 = 7.50
.Y2 = .250
.Z2 = 0
.X1 = 7.50
.Y1 = .250
.Z1 = 0
.X2 = .250
.Y2 = .250
.Z2 = 0
' ### Side Dado ###
.X1 = 9.750
.Y1 = 2.225
.Z1 = 0
.X2 = 9.500
.Y2 = 2.225
.Z2 = 0
.X1 = 9.500
.Y1 = 2.225
.Z1 = 0
.X2 = 9.500
.Y2 = 9.750
.Z2 = 0
.X1 = 9.500
.Y1 = 9.750
.Z1 = 0
.X2 = 9.750
.Y2 = 9.750
.Z2 = 0
.X1 = 9.750
.Y1 = 9.750
.Z1 = 0
.X2 = 9.750
.Y2 = 2.225
.Z2 = 0
End With
' -- Clean up
Set CLine = Nothing
End Sub
' Sub Declaration
Sub CreateOutline
Dim CLine
Dim intRet
With CLine
' ### Panel ###
.X1 = 0
.Y1 = 0
.Z1 = 0
.X2 = 0
.Y2 = 10
.Z2 = 0
intRet = CreateLine(CLine, mcCONSTRUCTION_COLOR_CURRENT, DEF_PANEL_LEVEL)
.X1 = 0
.Y1 = 10
.Z1 = 0
.X2 = 10
.Y2 = 10
.Z2 = 0
.X1 = 10
.Y1 = 10
.Z1 = 0
.X2 = 10
.Y2 = 2
.Z2 = 0
.X1 = 10
.Y1 = 2
.Z1 = 0
.X2 = 8
.Y2 = 2
.Z2 = 0
.X1 = 8
.Y1 = 2
.Z1 = 0
.X2 = 8
.Y2 = 0
.Z2 = 0
.X1 = 8
.Y1 = 0
.Z1 = 0
.X2 = 0
.Y2 = 0
.Z2 = 0
End With
' -- Clean up
Set CLine = Nothing
End Sub
'Rekd
[ 10-07-2003, 03:22 PM: Message edited by: Rekd ]
GRGERHARD,
To run a VBScript in Mastercam open the chook mcamvb.dll (ALT+C) and when the small dialog displays you can browse to your mcam9VB folder and select any one of the example scripts included with v9.1. If you have any problems or questions feel free to respond to this thread so I don't miss it.
Almost forgot, to view a script press the Edit button to open the selected script in Mastercams script editor.
[ 10-07-2003, 05:32 PM: Message edited by: Mick from CNC Software, Inc. ]
