Dynamic Offset Output (G54.2P#)
I am looking for some help on some post logic for outputting my dynamic work offsets for my ToyodaFH550SX. I currently have 8 dynamic offsets avalible on my machine and they are used in conjunction with the standard offsets (G54.1P#) of which I have 48 avalible.
output:
G54.2P# (where # could be 1-8)
G54.1P# (where # could be 1-48) See below
N30316510(SAFE START THIS LINE)
G0 G17 G20 G40 G80 G90
( TOOL 303165 - .1501 REAMER )
T303165
M6
S1200 M3
G90 G54.2P1
G54.1P20
G0 G90 B0
G90 G0 X-.287 Y-.789
G43H1 Z3.75
M8
Can this be done in the same way the HSM option is using the Misc. INT or Reals are for Hish Speed Machining accuracy, because i use this function too and it works pretty good when I need G05.1 Q1 R# output in my code.
This is getting away from the WCS workoffset asignment though and not sure that is what I want.
Thought a string table might be a possibility as well if i used the workoffset asignment in the WCS I could use a logical numbering sequence to get the desired offset output.
Any Direction on this would be greatly appriciated.
output:
T303165
M6
S1200 M3
G90 G54.2P1
G54.1P20
G0 G90 B0
G43H1 Z3.75
M8
Try so -
Only it is necessary to enter :
55 = G54.2 P1
56 = G54.2 P2
57 = G54.2 P3
58 = G54.2 P4
1 = G54.1 P1
2 = G54.1 P2
3 = G54.1 P3
4 = G54.1 P4
Here is what I came up with.
Thanks you response got me started.
Output When 8812 is in work offset
N235220
T235220
M06
(3 CLAP DICO PCD)
G00 G17 G90 G54.2 P8
G54.1 P12
S6500 M03
X-4.5553 Y5.2999
Post Code:
else,
if workofs$ > 8100 & workofs$ < 8149,
g_wcs = one
*g_wcs, e$
p_wcs = workofs$ - 8100
"G54.1", *p_wcs, e$
else,
if workofs$ > 8200 & workofs$ < 8249,
g_wcs = two
*g_wcs, e$
p_wcs = workofs$ - 8200
"G54.1", *p_wcs, e$
else,
if workofs$ > 8300 & workofs$ < 8349,
g_wcs = three
*g_wcs, e$
p_wcs = workofs$ - 8300
"G54.1", *p_wcs, e$
else,
if workofs$ > 8400 & workofs$ < 8449,
g_wcs = four
*g_wcs, e$
p_wcs = workofs$ - 8400
"G54.1", *p_wcs, e$
else,
if workofs$ > 8500 & workofs$ < 8549,
g_wcs = five
*g_wcs, e$
p_wcs = workofs$ - 8500
"G54.1", *p_wcs, e$
else,
if workofs$ > 8600 & workofs$ < 8649,
g_wcs = six
*g_wcs, e$
p_wcs = workofs$ - 8600
"G54.1", *p_wcs, e$
else,
if workofs$ > 8700 & workofs$ < 8749,
g_wcs = seven
*g_wcs, e$
p_wcs = workofs$ - 8700
"G54.1", *p_wcs, e$
else,
if workofs$ > 8800 & workofs$ < 8849,
g_wcs = eight
*g_wcs, e$
p_wcs = workofs$ - 8800
"G54.1", *p_wcs, e$
force_wcs = sav_frc_wcs
!workofs$
This is the same logic I use in my GibbsCAM post and it may seem a little weird but I have 2 Toyodas on an FMS with cell controller with 24 pallets and 500+ tool on each machine. The cell controller has a funny way of asigning work offsets and this numbering logic sort of follows that logic. In our cell controller offset 81 writes to the dynamic P1 offset (G54.2P1) so 81-88 can be used to output dynamic G54.2P1-8 and it uses 11-59 to output G54.1P1-48. These offsets are stacked (both are used) where the major offset from table center to part location is in the dynamic register and the fine adjustment are entered into the standard G54.1P# offset register. So in the CAM system I decided to use a sequencing logic where any workoffset number 8101 - 8848 can be used to output any of the avalible work offsets to the code.
Example:
G54.2P2
G54.1P16
would be output when work offset register is 8216
or
G54.2P8
G54.1P1
would be output when work offset register is 8801
