5 axis machine configuration
Im using Mastercam X and am trying to get 5 axis swarf toolpaths to post properly. The machine in use is a Haas Vf-4 with a trunnion. The trunnion axis are A and B. So it would be a table-table configuration. What has me confused is that there does not seem to be a machine configuration to suit this. The closest one is a table-table horizontal configuration. So my problem is after I make the toolpath I post it and the B axis is replaced with a C axis (that the machine doesn't have). I messed a little bit with editing the machine configurations in the machine group properties and when I thought I had it correctly configured to use A and B as my rotary axis, I get an error saying the machine configuration doesn't allow for that type of toolpath. Any help would be appreciated.
(PROGRAM NAME -  2222 )
(DATE=DD-MM-YY -  29-09-15  TIME=HH:MM -  13:47 )
N100 G20
N102 G0 G17 G40 G49 G80 G90
/ N104 G91 G28 Z0.
/ N106 G28 X0. Y0.
/ N108 G92 X10. Y10. Z10.
(  1/2 BALL ENDMILL   TOOL - 1  DIA. OFF. - 1  LEN. - 1  DIA. - .5 )
N110 T1 M6
N112 G0 G90 X.2298 Y-.3944 A-12.487 S1069 M3
N114 G43 H1 Z3.3926
N116 X1.9555 Z-.1048
N118 G1 X1.9998 Z-.1945 F40.
N120 X1.8019 Y-.4692 Z-.2831 A-12.571 F14.64
N122 X1.7598 Y-.464 Z-.2884 A-12.491 F75.01
N124 X1.7488 Y-.4659 Z-.2705 A-12.485 F10.77
N126 X1.7118 Y-.4665 Z-.2765 A-12.494
N128 X1.6835 Y-.4662 Z-.2781 A-12.488
N130 X1.6348 Z-.278 A-12.487
N132 X1.1873 Z-.2895 F40.
N134 X.8695 Z-.2949
N136 X.577 Z-.2975
N138 X.2841 Z-.2977
N140 X-.0085 Z-.2954 A-12.488 F.08
This post swapped out the B moves for F...... Im stumped
okay so that was expected as I had the machine type set to default. Here is another post for the toolpath with 5 axis table - head vertical selected.
102 G20
N104 G0 G17 G40 G80 G90 G94 G98
N106 G0 G28 G91 Z0.
N108 G0 G28 X0. Y0.
N110 (  1/2 BALL ENDMILL   TOOL - 1  DIA. OFF. - 1  LEN. - 1  DIA. - .5 )
N112 T1 M6
N114 G0 G54 G90 X3.8773 Y.4114 C-66.337 B-28.889 S1069 M3
N116 G43 H1 Z6.8807
N118 Z2.9807
N120 G1 Z2.8807 F40.
N122 X3.7011 Y.2627 Z2.9089 C-65.861 B-28.603
N124 X3.6375 Y.2597 Z2.9521 C-65.533 B-28.141
N126 X3.5929 Y.2837 Z3.0231 C-64.685 B-27.377
N128 X3.5396 Y.2802 Z3.0571 C-64.229 B-27.005
N130 X3.4934 Y.2818 Z3.0919 C-63.772 B-26.617
N132 X3.4081 Y.289 Z3.1596 C-62.799 B-25.849
N134 X2.6085 Y.3467 Z3.6606 C-50.911 B-19.353
N136 X2.0365 Y.3985 Z3.9141 C-35.996 B-15.308
N138 X1.5955 Y.4253 Z4.0565 C-14.787 B-12.901
N140 X1.3924 Y.3799 Z4.1043 C11.237 B-12.723
N142 X1.5296 Y.2792 Z4.0557 C33.466 B-14.868
N144 X1.7148 Y.2247 Z3.9905 C42.414 B-16.687
N146 X1.7448 Y.2174 Z3.9788 C43.728 B-16.967
N148 X1.7852 Y.214 Z3.9619 C44.907 B-17.39
N150 X1.8445 Y.2038 Z3.94 C45.946 B-17.937
Thats not the entire program but just so you get it. The B axis movements look to be correct but I've got a C axis in there and I'm only working with XYZAB
When you go to the Machine Type menu, use the "Manage List" function. There should be a copy of that MD/Post that installs by default. You will have to "add" the entry to your list, and then you should be able to select it.
As an alternative, if you load "any" 5X machine, you should be able to open the "Machine Group Properties" and do a "replace" on the machine definition file. Just pick the Generic Haas VF-TR_SERIES 5X Mill, and you'll be all set...
