Back Boring operation in Hass VF5 using Mastercam 2017
M.Rohit
Hi every one!
I need help in performing a Backboring operation, with certain parameters to be followed like,
1.  Machining must happen in reverse Z travel.
2. The tool must enter in 20 dia bore at the center from the Top and perform the back boring operation to form 25 dia bore in absolute coordinate system at  (-100 mm) Z-axis to (-95mm) Z - axis
then the tool must align to center at -95 mm to avoid collision and return to 0 mm (Z-axis)
Kindly help me out to choose what tool path can be used to perform this operation.
Thanks in Advance!
Since you already know the machining parameters, I'd suggest using a Manual Entry path, and simply typing in the code you need to machine the feature.
The way we normally do this in Mastercam is by defining a Custom Drill Cycle. But that typically is something that you would pay your Reseller or a 3rd Part Developer to build for you.
Sir,
Humbled  by your reply, certainly will do it. Can  you help me out sharing some notes or information relating to custom programming , manual programming ?
It would be of great help if you can share some programming materials.
Here is my mail ID : [email protected]
Thanks alot,
