Sign in to follow this
LMVUICHARD
VB.NET (VS2019) MC2020 Misunderstanding MCView
Hello,
I’m beginner in Hook and vb.net, but I try to build some dedicated applications. I have write some, with success, but now I meet an issue, difficult I think, to solve by myself.
I need to move some geometrys between views, and I think I have some misunderstanding about how Mastercam Mcview run.
To explain more simply what I mean, I have write a very small test where I draw one Arc in Top view and try to move it on different arc plane.
That works normally for standard Mcam view, but not in any no-standard view, why?
It Seem, with a no-standard view, that Mcam move geométries in the current display view plane.
how is it possible to place them in the selected arc plane?
Thank's in advance for your help
Code:
' <copyright file="NethookMain.vb" company="CNC Software, Inc.">
'   Copyright (c) 2018 CNC Software, Inc.
' </copyright>
' <summary>
'  If this project is helpful please take a short survey at ->
' http://ux.mastercam.com/Surveys/APISDKSupport
' </summary>
Imports Mastercam.App
Imports Mastercam.App.Types
Imports Mastercam.IO
Imports Mastercam.Support
Imports Mastercam.Curves
Imports Mastercam.Database.Types
Imports Mastercam.Math
Public Class NethookMain
    Inherits NetHook3App
#Region "Public Methods"
    ''' <summary>
    ''' This method is designed to be the main entry point for your NetHook app. This is where your app should do
    ''' all of the things it's supposed to do and then return an MCamReturn value representing the outcome of your
    '''  NetHook application.
    ''' </summary>
    ''' <param name="param">Parameter is not used</param>
    ''' <returns>A <c>MCamReturn</c> return type.</returns>
    ''' <remarks></remarks>
    Public Overrides Function Run(param As Integer) As MCamReturn
        Dim ArcSup As ArcGeometry
        Dim a As ArcGeometry
        Dim ConvertToWorldCoordinates As Point3D
        Do
            If SearchManager.GetSelectedGeometry().Any() Then
                SelectionManager.UnselectAllGeometry()
            End If
            a = SelectionManager.AskForGeometry("Select Arc", New GeometryMask(False, False, True, False, False, False, False, False))
            If IsNothing(a) = True Then
                Return MCamReturn.NoErrors
                Exit Function
            End If
            ArcSup = New ArcGeometry(SearchManager.GetViews(1)(0), New Point3D(0, 0, 0), 15.0, 0.0, 360.0)
            ArcSup.Commit()
            ConvertToWorldCoordinates = ViewManager.ConvertToWorldCoordinates(a.Data.CenterPoint, a.ViewNumber)
            ArcSup.Translate(New Point3D(0, 0, 0), ConvertToWorldCoordinates, SearchManager.GetViews(1)(0), a.View)
            GraphicsManager.ClearColors(New GroupSelectionMask(True))
            GraphicsManager.Repaint(True)
            a = Nothing
        Loop
    End Function
#End Region
End Class
Something to try.
Note that it's looking for the Plane (view) with the name of "MyTargetPlane" to use as the to Translate To View.
Private Function TranslateArc() As Boolean
    Dim entTypeMask = New GeometryMask(False) With {
        .Arcs = True
    ' Ask the user to select a single Arc geometry item.
    Dim geom = SelectionManager.AskForGeometry("Select Arc", entTypeMask)
    If geom Is Nothing Then
        Return False
    End If
    ' Cast the Geometry to it's specific type.
    ' We know it's an Arc, so this direct-cast is safe.
    Dim arc = CType(geom, ArcGeometry)
    ' Get ALL MCView (Planes) data in the file.
    Dim allViews = ViewManager.GetAllViews(False)
    ' Search for the destination view "by name".
    Dim targetView = New MCView()
    Dim found = False
    For Each view In allViews
        If String.Compare(view.ViewName, "MyTargetPlane", StringComparison.OrdinalIgnoreCase) = 0 Then
            targetView = view
            found = True
            Exit For
        End If
    Next
    If Not found Then
        Return False
    End If
    ' Create a new Arc and the same center point as the selected arc in Top.
    Dim topView = SearchManager.GetSystemView(SystemPlaneType.Top)
    Dim arcSup = New ArcGeometry(topView.ViewNumber, New Point3D(0, 0, 0), 15.0, 0.0, 360.0)
    arcSup.Commit()
    ' The center point of the selected arc in world coordinates.
    Dim ptWorldCoordinates = ViewManager.ConvertToWorldCoordinates(arc.Data.CenterPoint, arc.ViewNumber)
    ' Translate this new arc to the "MyTargetPlane" view.
    Return arcSup.Translate(New Point3D(0, 0, 0), ptWorldCoordinates, topView, targetView)
End Function
Thanks for your very quick answer!
I have try your code, but it don’t solve my issue.
If the user click on an Arc based on a no-standard view -> this view don’t have any name, and your routine create nothing!
I have try to address the name this no-standard arc view, with:
        If arc.View.ViewName = "" Then
            arc.View.ViewName = "tibidi"
            arc.Commit()
        End If
        Dim TargetName As String = arc.View.ViewName
        'Dim TargetName As Integer = arc.View.ViewNumber
        Dim found = False
            If String.Compare(view.ViewName, TargetName, StringComparison.OrdinalIgnoreCase) = 0 Then
                targetView = view
                found = True
                Exit For
            End If
        Next
But, again, this solve nothing, because:
Load only standard Mastercam views, from “top” to “trimetric”, but not the "exotics" views...
I am not sure what you mean be "exotic" views.
Mastercam has Named Planes (views). Those are displayed in the Planes Manager pane in Mastercam.
ViewManager.GetAllViews(False) retrieves ALL of these known views.
The arc you have the user select contains ViewNumber data of the view that arc is in.
You can work with that value to get all of the Plane (MCView) data for the arc’s view if needed.
Sorry, if my explainations are not clear... my english is not at it's top, but i can try to explain again,  thank you, for your effort of understanding!
If, in Mcam, in top view, you draw one arc at any position, and in front cplane you rotate it arond origin of 45°
-> this arc depend of no referenced named view in the view manager.
It's this "no name", what i have named "exotics view".
if we analyse it, it's view number is 21.
it's the same in the code, arc.viewnumber=21
It's the reason i don't have use the named view, and beause of that it's impossible to search, for these arcs, the named views.
In my original code, it' the reason i have try to use "a.view", the arc's Mcview clicked by the user for the plane rotation.
I have try to understand what was going on and have analyse all arc data.
i think the problem come from  the returned arc's Mcview matrix, who is changed, depending on the display view.
i have try to load it in a new MCview, and convert it each point in WCS, but it's run approximatively only if i try it in a top view.
i don't know what it be possible to do to have directly the arc's MCview, in WCS coordinates who can be simply use in the .Translate command.
its more clear for you?
I can give you some examples, but if you make only one top arc rotation from any side view, you can see my code is wrong, and your's proposal make nothing.
Thank's for your help.
To try to give a clearers explainations:
1/ Mastercam part:
2/Modifications in your code:
        Dim found = False
3/Result:
4/ Second modification in your code:
                targetView = view
                found = True
                Exit For
            End If
        Next
        targetView = arc.View
        found = True
        If Not found Then
            Return False
        End If
(Ok, after that , a lot of lines are useless, but it's for the test…)
5/ Result:
Obviously, there is a link with the graphic view...
I think this may be what you are looking for.
If not, email us:  Your code sample file and company contact info to > SDK [at] mastercam [dot] com
As you see in the View data for the arc you have the ViewNumber of the selected arc. You can use that View Number data.
// arc = the user selected arc
var ctr = ViewManager.ConvertToWorldCoordinates(arc.Data.CenterPoint, arc.ViewNumber);
// Use this as the center point for the new arc...
NET-Hook API Docs - https://nethookdocs.mastercam.com
See in Mastercam.IO.ViewManager:
Point3D ConvertToViewCoordinates(Point3D WorldCoordinates, short ViewNumber)
Point3D ConvertToWorldCoordinates(Point3D ViewCoordinates, MCView View)
Point3D ConvertToViewCoordinates(Point3D WorldCoordinates, MCView View)
Thank you very much for your help!
 I have seen the online documentation, i work already with.
 I find it a little bit succinct and lack set of examples of uses (I know, you maked some application examples, i have download it, but nothing about Mcview for example).
It exists, it's already good, and I understand the work it requires...
I had try to use both commands "ConvertToViewCoordinates" and "ConvertToWorldCoordinates",
to now, without any success...
Probably, due to some misunderstanding from my side about how these two commands really runs.
For the moment, I don't have any time left, but I'll look at that up quietly as soon as possible.
I note the e-mail adress and will use it if i don't find myself any solution.
Thank's again!
