NPT Thread mill toolpath
  • Please log in to reply
7 replies to this topic
#1 MasterCAM Rulez
MasterCAM Rulez
    Member
  • Members
  • PipPip
  • 77 posts
Posted 01 May 2002 - 06:02 PM
I need to create a  1.5-11.5 NPT internal thread, I'm not sure if I do it right, i need some help and recommendation.
Alt+C,Thelix-->
1. Enter the Radius: .95
(top internal diameter of thread is 1.9O0/2 =.95)?
2. Enter the starting angle: O
3. Enter the incremental angle: 5.
(what angle value should enter i need a recommendation)? !HELP!  confused.gif
4.Enter the number of revolutions: 4
5.Enter the pitch: .08695
(1/11.5 =.08695)?  confused.gif
6. Enter the taper angle: 1.79
7.Point entry: Origin
Toolpath
Toolpath,Next Menu,Circle toolpath,Thread Mill,
entities, chain (select the helix geometry),Done, done, done
At TOOL PARAMETER where it said " TOOL DIAMETER",
I use thread milling insert.
Thanks in advance
#2 Jammer™
Jammer™
    Barefoot CNC
  • Resellers
  • PipPipPip
  • 8,772 posts
Posted 02 May 2002 - 01:41 AM
We just did a bunch of thread milling and found several ways to do it. If your using a thread milling insert, you might want to try: Toolpaths, next menu, circ tlpths, thread mill. Set up your tool parameters, then under thread mill parameters you can set your depth, pitch, etc. The pitch on a 1.5-11.5 is (.08696) You might have to play with your settings a bit to achieve what you want, but it seemed to work pretty well for me. I use a thread mill cutter made by Advent. You might want to check them out. www.advent-threadmill.com  You really need to know all the specs of the tool your using, and pick the min. diameter of your hole to be threaded. It really makes a difference on how the toolpath will be generated. Play around with it and you will see how much changing parameters affects the toolpath. Good luck!
#3 kccadcam
kccadcam
    'puter nerd
  • Members
  • PipPipPip
  • 854 posts
Posted 02 May 2002 - 10:14 AM
In V9 go to toolpaths, next menu, circ tlpths, threadmill, there is a box to fill in your taper angle for pipe threads. Works great and is easy!!
#4 MasterCAM Rulez
MasterCAM Rulez
    Member
  • Members
  • PipPip
  • 77 posts
Posted 02 May 2002 - 08:34 PM
i have a problem when i toolpath a NPT.
1. I already use Alt+C to create 1.5-11.5 NPT thread, the geometry on the scene show the helix move taper (1.79)on XY axis.
2. but when i toolpath the geometry, the toolpath doesnt move taper (1.79)on XY axis, it just cut like a normal thread (UNC or UNF)
Thanks in advance
#5 Guy
Guy
    Member
  • Members
  • PipPip
  • 52 posts
Posted 03 May 2002 - 04:22 AM
#6 Jammer™
Jammer™
    Barefoot CNC
  • Resellers
  • PipPipPip
  • 8,772 posts
Posted 03 May 2002 - 08:03 AM
Charlie, I created a thelix using the parameters you gave. I used a 1.000 dia. cutter (just for the hay of it) and it cut the taper on the helix like it should. If you are going to use a thelix to do it, make sure in your parameters that you have cutter compensation set to "off" on both controls. I would recommend you using the "thread mill" toolpath instead of the c-hook "thelix". I think you will have better luck.
#7 kccadcam
kccadcam
    'puter nerd
  • Members
  • PipPipPip
  • 854 posts
Posted 03 May 2002 - 11:59 AM
I agree with jammer,
use the "threadmill toolpath" --- go to            toolpaths,next menu,circle toolpaths,threadmill-- then all you have to do is pick points just like drilling, fill in all your parameters including taper angle and you'll be on your way.
#8 MasterCAM Rulez
MasterCAM Rulez
    Member
  • Members
  • PipPip
  • 77 posts
Posted 03 May 2002 - 12:29 PM
Mr. William can you write down step by step how you do it (1.5-11.5 NPT thread), maybe i missed something.   smile.gif
Thanks in advance
