generic haas vf-tr_series 5x mill.pst
I am having an issue that may be in the post or the way I am programming. I am using X7, I have a new Haas VF3 with a TR110 5 axis trunen. the problem i am having is the (A axis is the tilt B rotary) A axis keep moving to front to back to machine the part from both sides in stead of rotating B axis 180 degrees. I am trying to keep all the machining to the front where I can see it. Is there a setting in mastercam control def or post that let it stay up front. I attached a zip and go called TEST
D Coffin
www.rayginn.com
TEST.Z2G
I am guess your op2 is the one in question? Everything in Mach simulation looks ago, but without a machine to run it on myself I would be guessing. What operations are the one that are giving you issues? You have all the operations with mi9 set to 2 for Nutating Bias Neg when you change that value what happens to the output? I did see a big difference when I used the mi10 and I got the A values to be A90. instead of A-90. Looks ot me like you are using the wrong mi to make your changes. The Secondary seems to be making the difference you are looking for not the Primary.
