Any one using the G1216 and other GXXXX Canned cycles on the Fanuc Oi-Mc Control?
crazy^millman
Was loking up something in the book and stubled across these and was wondering if anyone was using them? Look like things I seen on other machines and for simple set-up and facings was thinking about letting the set-up people use them if they are worth a darn. Your thought and suggestions are welcome.
Machining question not a geo poltical question so I do not consider it OT.
Well you know you can set these up as custom drill cycles. Here is what I did for a fadal few years ago.
# Canned Cycle Variables
pocfeed	= peck1   #Feed for the Pocket on Canned Cycles
pocstep	= peck2   #Step Over for Rectangular & Circular Pocket L9601 & L9602 & L9801 & L9802
pocwidth   = peckclr #Overall Width for Rectangular Pocket L9601 & L9602
pocheight  = retr	#Overall Width for Rectangular Pocket L9601 & L9602
pocdia	 = peckclr #Diameter for Circular Pocket L9801 & L9802
pocdepth   = depth   #Depth for Pocket Routines
pocout	 = refht   #Clearence for Pocket Routines
engout	 = refht   #Clearence for Engraving
engfont	= peck1   #Font for Engraving 0=Std Gothic, 1= Stencil Gothic, 2=Ser Std, 3=Ser Stencil
engheight  = peck2   #Height to Engrave Characters
engangle   = peckclr #Angle to Engrave Characters
engser	 = retr	#Serlization Engraving
engword	= dwell   #Overall Width for Rectangular Pocket L9601 & L9602
#pocdia	 = peckclr #Diameter for Circular Pocket L9801 & L9802
#pocdepth   = depth   #Depth for Pocket Routines
#pocout	 = refht   #Clereance for Pocket Routines
fmt  R0 2   refht_a	 #Reference height (0) is added to work correctly for Fadals
fmt  R0 2   refht_i	 #Reference height (0) is added to work correctly for Fadals
fmt  R0+ 2   pocfeed	 #Feed Rate for Rectangular Pocket L9601 & L9602
fmt  R1+ 2   pocstep	 #Step Over for Rectangular & Circular Pocket L9601 & L9602 & L9801 & L9802
fmt  R2+ 2   pocwidth	#Overall Width for Rectangular Pocket L9601 & L9602
fmt  R3+ 2   pocheight   #Overall Width for Rectangular Pocket L9601 & L9602
fmt  R2+ 2   pocdia	  #Diameter for Circular Pocket L9801 & L9802
fmt  R0+ 2   engout	  #Clearence for Engraving
fmt  R1+ 2   engfont	 #Font for Engraving 0=Std Gothic, 1= Stencil Gothic, 2=Ser Std, 3=Ser Stencil
fmt  R2+ 2   engheight   #Height to Engrave Characters
fmt  R3+ 2   engangle	#Angle to Engrave Characters
fmt  R4+ 2   engser	  #Serlization Engraving
fmt  (   4   engword	 #Text to Engrave
fmt  Z  2	pocdepth	#Depth for Pocket Routines
fmt  Z  2	pocout	  #Clereance plane for Pocket Routines
fmt  Z  2	engout	  #Clereance plane for Engraving Routine
pmisc1		  #Canned Misc #1 Cycle
  pdrlcommonb
  tloffno = t
  pcan1, pbld, n, *sg01, *pocdepth, *feed, *tloffno, e
  pbld, n, "L9601", *pocfeed, *pocstep, *pocwidth, *pocheight, e
  pbld, n, sg00, *pocout, e
  pcom_movea
pmisc2		  #Canned Misc #2 Cycle (User Option)
  pdrlcommonb
  tloffno = t
  pbld, n, "L9701", *pocfeed, *pocstep, *pocwidth, *pocheight, e
  pcom_movea
pdrill_2		#Canned Drill Cycle, additional points
  pdrlcommonb
  pcan1, pbld, n, pfxout, pfyout, pzout, pcout, prdrlout, dwell,
	feed, strcantext, e
  pcom_movea
ppeck_2		 #Canned Peck Drill Cycle
  pdrill_2
pchpbrk_2	   #Canned Chip Break Cycle
  pdrill_2
ptap_2		  #Canned Tap Cycle
  pdrill_2
pbore1_2		#Canned Bore #1 Cycle
  pdrill_2
pbore2_2		#Canned Bore #2 Cycle
  pdrill_2
pmisc1_2		#Canned Misc #1 Cycle
  pdrlcommonb
  pbld, n, sg00, pfxout, pfyout, pfcout, e
  pcan1, pbld, n, *sg01, *pocdepth, *feed, e
  pcom_movea
pmisc2_2		#Canned Misc #2 Cycle
  pdrlcommonb
  pcom_movea
pdrlcst		 #Custom drill cycles 8 - 19 (user option)
  #Use this postblock to customize drilling cycles 8 - 19
  pdrlcommonb
  if drillcyc = 8,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L9201", *engout, *engfont, *engheight, *engangle, *engser, *engword, e
	 pcom_movea
  if drillcyc = 9,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L94", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	 pcom_movea
  if drillcyc = 10,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L95", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	 pcom_movea
  if drillcyc = 11,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L9801", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	 pcom_movea
  if drillcyc = 12,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L9901", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	 pcom_movea
  pcom_movea
pdrlcst_2	   #Custom drill cycles 8 - 19, additional points (user option)
  pdrlcommonb
  if drillcyc = 8,
	  pdrlcommonb
	  pbld, n, "L93", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	  pcom_movea
  if drillcyc = 9,
	  pdrlcommonb
	  pcom_movea
  if drillcyc = 10,
	  pdrlcommonb
	  pcom_movea
  if drillcyc = 11,
	  pdrlcommonb
	  pcom_movea
  if drillcyc = 12,
	  pdrlcommonb
	  pcom_movea
  pcom_movea
Hope that gives you some ideas.
Each builder does something a little different with their Operator Panels. Many are alike but usually there's some subtle differences. Most of the time the Fanucs are close enough to each other that you can navigate your way around but ofter the little things like HD T and NX T, Spindle Load, Modal Codes, etc...
  • 16 years later...
