HOW TO MOVE A MISC INTEGER COMMENT IN POSTED CODE
      pcan
      #pbld,  *sgcode, *sgabsinc, sg80, e$ #ADDED
      pbld,  sg43, *tlngno$, pfxout, pfyout, pfzout,  [if nextdc$ <> 7, *speed, *spindle], e$ # G43 with spindle start
      if mi4$,
       no_spc$, "G91 Z#612 (BLADE THICKNESS ADJUST)", no_spc$, e$
       pbld, "G90", e$
GETS ME THIS:
G0 G90 X.1035 Y4.8144
G43 H99 Z.15 S9000 M3
G90
Z.057
G1 Z.047 F50.
G41 D99 X.0156 Y4.8621 F27.
THIS IS WHAT I NEED:
Z.057
G1 Z.047 F50.
G90
Do you want the two lines of code inserted every time there is a z move? If so, I think you would need to copy your mi4 if statement to right before the G41 cutter comp line.
In the MPFAN post the G41 cutter comp line is in the following postblocks:
prapidout
plinout
pcirout
I believe you'll get what you're looking for if you paste the mi4 if statement right before the cutter comp line.
prapidout
plinout
pcirout
The issue is the 'misc values' get reset when you aren't processing a 'Tool Change'.
You can setup a 'flag variable' to track the status of 'mi4$', and delay the output until processing in 'plinout'.
G0 G90 X.1035 Y4.8144             < OUTPUT FROM TOOL CHANGE (Either 'psof$' or 'ptlchg$)
G43 H99 Z.15 S9000 M3            < OUTPUT FROM TOOL CHANGE (Either 'psof$' or 'ptlchg$)
Z.057                                             < OUTPUT FROM 'prapidout' (G-code 0)
G1 Z.047 F50.                               < OUTPUT FROM 'plinout'      (G-code 1)
G41 D99 X.0156 Y4.8621 F27.   < OUTPUT FROM 'plinout'      (G-code 1)
Start by initializing a variable, near the top of your Post:
mi4_flag           : 0
Then, capture if the value is '1' during Tool Change (need to put this in 'psof$' and in 'ptlchg$'):
      pcan
      if mi4$, mi4_flag = yes$ #Set flag
      else, mi4_flag = no$   #Reset if necessary
Now, add your logic to 'plinout':
 plinout         #Output to NC of linear movement - feed
      pcan1, pbld, n$, sgfeed, sgplane, `sgcode, sgabsinc, pwcs, pccdia,
        pxout, pyout, pzout, pcout, [if motst$, feed], strcantext, pscool, e$
      #Modify following line to customize output for high-speed toolpath
      #tool inspection/change points
      if rpd_typ$ = 7, pbld, n$, "M00", "(TOOL INSPECTION POINT - POST CUSTOMIZATION REQUIRED)", e$
      if mi4_flag,
        "G91 Z#612 (BLADE THICKNESS ADJUST)", e$
        pbld, "G90", e$
        mi4_flag = no$ #Reset Flag, to prevent output on every "linear move"
