2024 Verify/Stock Model Bug
TFarrell9
This bug involves using 2D Mill Contour Ramp in the Lathe environment.
Both Verify and Stock Models will generate like the tool made an extra revolution at the same pitch and cut too much material. This bug is countered by checking the "linearize helixes box". Verify and Stock Models will generate properly after that.....of course now you have more code.
This is a consistent issue for me and I'm curious to know if others are experiencing this as well.
It does what is expected for me, I created paths from 'Lathe - C-axis - Face Contour' and 'Milling - 2D - Contour"
The only difference I see between the 2 is start position.
*EDIT*
I stand corrected, I do see this in  Verify but only for the lathe face contour path. The g-code however posts correctly with the tool going to the correct depth.
Edited by AHarrison1
*EDIT*
I hadn't tried it with the C-axis path yet, but that's interesting it does it with that path as well. They're probably the same path at the core I suppose.
Regarding the code being correct, that's my experience as well. Backplot and code are both correct.
I first noticed this bug a couple weeks ago when updating a 2023 file that we ran a month or two ago. I ran it through Verify and saw the issue and initially thought something happened with my toolpaths.
