3+2 question
DavidB
Hi again all,
Can someone please explane to me what this means.
In the training notes it says:
The primary rotation is defined by selecting the gnomon vector that defines zero and assigning it to 'rotaxis1'
I want to set my primary axis to rotate about the Z axis of a Vertical machine.
#Primary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis must be the XY plane
rotaxis1 = vecy #Zero ?????????????????
rotdir1 = vecx #Direction ??????????????
Hi again David,
I'm thinking this means that the primary rotary 0 degrees is vecy which is at 12 o'clock position looking down from the top view, and rotation positive direction is rotation from vecy to vecx so the table would actually rotate counterclockwise for positive angular motion,
but I'm not sure .
Jim
Jim put like that i understand Thx.
So if i want my table to rotate CCW for a positive direction I would have.........
rotaxis1 = vecx #Zero
rotdir1 = vecy #Direction
That would be for the Primary which rotates around Z.
Now for the secondary which rotates around machine Y axis would you look at it from the front of machine or the back of machine?
rotaxis2 = vecx #Zero ??????????????
rotdir2 = vecz #Direction ??????????
Looking from the front i need the rotation to be CCW for a positive direction
Thx for all the help
David,
You're on the right track. For your primary
zero degrees rotaxis1=vecx would mean at 3 oclock top view, I think CCW positive direction should be rotdir1=-vecy
not sure about secondary, you'll have to test it to see the output, if rotaxis2=vecx gives you the
proper tilt zero deg position, but rotdir2=vecz is the wrong direction, change it to rotdir2=
-vecz.
Cheers,
Jim
David,
With the part WCS set to top, you will have to create the c/plane and t/plane normal to the specific feature you want to drill/mill. Once you've established that (I always write down the c/plane number created in case I have to go back to it) go ahead and make your toolpaths (other than multiaxis) and the post should output both rotary positions once the way you want. Then you can work on the next feature you want, by creating a new c/plane, t/plane for that.
Jim
