Help with Variaxis 500 post
mgsanchez
This is my first post to the forum. I would first like to thank everyone for all the great information available on the forum. I have been able to get our posts the way our programmers and operators like to see the output to the machines based on the information available here and from the post manual.
We are using v9.1 MR0304 Mill level3. We purchased a post for our Mazak Variaxis 500 from Mastercam thru our reseller which worked good right from the start. The post looks like it started life as a MPGEN5X. The post is coded to our hasp.
I have come across on problem that I have been unable to solve. The machine travel in the Y+ direction is 6.1" and 13.98" in the Y- direction. When trying to drill a bolt hole circle of 12.2" or greater diameter the code is correct but, the machine alarms because the the output is greater than 6.1" Y+ direction. We have been MDI coding to get around this problem. curse.gif I more thing I noticed, regardless of what quadrant the first hole picked is located the output for the first hole is always located in the Y+ direction, if this helps.
Now for my question, how can I get the post to rotate the C axis 180 degrees and change the A axis (when drilling at an angle) when the hole is located greater than Y+6.1"?
Below is a single tool example of our output as posted:
:0001 (VARIAXIS PLATE POSITION TEST )
( SEP - 17 - 2004 , 13:54 )
( Programmer: MGS )
(X0,Y0,Z0 = Center, Center, Top )
(STOCK ORIGIN = X0. Y0. Z0. )
(MATERIAL TYPE= STEEL inch - 304 STAINLESS )
(MATERIAL SIZE= X17. Y17. Z.5 )
( T10 3/8 DRILL 304 STAINLESS )
M912
G0 G17 G20 G40 G61.1 G80 G90 G94 G98
G0 G28 G91 Z0.
G0 G28 X0. Y0.
T10 M6 ( 3/8 DRILL 304 STAINLESS )
M01
( DRILL HOLES @ 67 DEGREES )
G0 G54 G90 X0. Y6.4435 C-90. A-23. S611 M3
G43 H10 Z5.7351 M8
G83 G98 Z2.1851 R2.9851 Q0. F3.5
Y-6.4435 C-150. A23.
Y6.4435 C-210. A-23.
G94 G80
M9
M5
G0 G28 G91 Z0.
G0 G28 X0. Y0.
G28 C0. A0.
M911
M30
Sorry for the short story long.
Thanks for your help.
Mike
I would think you can you need to set the limits of travel in one axis or the limits of rotation to accomdate this. When you contact the reseller about this what has been their response. Since you got it through them be best to let me get it the way you want. The idea is not only do you get soemthing you need but they get a better understanding of your needes if they understand what you needs are.
Thanks Ron,
I tried to set the machine Y+ limits, but that did not work.
up_y_lin_lim : 6.1 #Y axis limit in positive direction
The original value was set as
up_y_lin_lim : 20.0
I also played around with
adj2sec : 1 #Attempt to adjust the primary axis from secondary?
#Allows primary axis to flip 180 to satisfy secondary
#0 = Off
#1 = Use method when secondary is out of limit
#Use with pri_limtyp = one to keep secondary as controlling
#limit when limit tripped
#Use with pri_limtyp = two to allow 180 degree reposition
and with
#Set pri_limtyp and sec_limtyp on following conditions
#0 = Less than 180 degrees
#1 = Equal or greater than 180 degrees and less than 360 degrees
#2 = Soft limit at 0-360 degrees with hard limits slightly beyond
#Set limhi-limlo to hard limits, inthi-intlo to 360 degrees total
#limhi-limlo are expected equal amount from inthi-intlo
#3 = Greater than 360 degrees
auto_set_lim : 1 #Set the type from the angle limit settings (ignore these)
pri_limtyp : 0
sec_limtyp : 0
My guess is that there is a combination of things to set, I am just not sure which ones.
I have not contacted our reseller. The problem has not been a show stopper for us. I was just hoping this would be a quick fix from the guru's here.
I met Mike Rosa, Applications Manager, from Masteram at Mazak's "Touch the Future" last year while we were waiting for our Variaxis 500 delivery. That is when I learned of the post for the Variaxis. Our reseller then contacted Mike Rosa for the post.
I am guessing that Mike went to IMTS since I had seen him again at Westec. I am planning to send an email to Mike Rosa this week. I just thought I would give him a chance to settle back in if he did indeed go to IMTS.
Thanks again,
Mike
Thanks Ron,
I have looked in the 5 axis PDF for some answers. I have also looked in my Mastercam Handbook Volume 3 and the post manual for answers. I probably skipped over the most important parts.
I sometimes can't see the forest because of all the trees. banghead.gif I will look again. I will also look on the FTP site.
Mike
Ron
Thanks for the hint, I found the problem, our post is missing the ability to utilize mi10 like the generic MPGEN5X. I was unable to get our post to work by adding the mi10 function. I was able to rewrite the MPGEN5X post to match the post we purchased from Mastercam. It was a long day at work testing the post, but well worth it. Works great!
Mike
