WCS and 5 axis
Bruce Caulley
Can a wcs be used together with 5 axis machining using defined views?
To save time and allow checking between op1 and op2 I have started programming a job from both sides.
Let me clarify.
WCS top: machine part from top face and front and back using single datum set at top and centre of bounding box
WCS #: wcs set as top and centre of bounding box as seen if part was flipped over. I have then had to create 3 different views to allow machining on angled faces. When I select the origin for these views as the origin of the "bottom" wcs, I get a different x,y,z value for each one. I would have thought that they would be the same.
Will this effect anything when I post the programmes?
Bruce
I know i could just post it and check but I don't have the machine time available. MC is a deckel dmu50
[ 09-24-2004, 03:53 AM: Message edited by: BC10146 ]
Bruce,
unless you are actually locating the part on a already machined face and you need to use a different datum, I would leave the origin button well alone. If you have turned the part over, create a new wcs for that view, and use the same datum if you can. Do you have a file you can upload onto the FTP?
Tinny
I do have a file but I would end up in front of a firing squad if I showed it.
What I usually do with a part that has 2 5 axis ops is have an mc9 file for one side and another for the back. This is a pain sometimes because I need to verify, save as stl, xform stl use as stock model for the 2nd op file, get a watertight stl problem blah blah blah.......
What i am doing now is both 5 axis ops in 1 file. That way when I verify I end up with the completed part and I can see if any of the first op processes have interfered with the second op. Our 5 axis post uses a single datum so when I create a view I must set the origin for that view as 0,0,0. If i am in a wcs other than #1 top and I set a new view I select the origin on the screen as the view origin the x,y,z values are different for each new view. If I create views while in wcs#1 and select the origin on the screen I get 0,0,0 no matter what.
I have been ploding away on this for a couple of hours and it all looks good. I was just wondering if anybody else had used a combination of wcs and custom views in the same file before.
I have posted some of the toolpaths and they look alright. I will continue this and see if it is successful as it will be a big help on complex 5 axis parts that we currently do in multiple mc9 files.
Bruce
Hey Bruce.
What works for me is to create the initial Top View using the WCS, then as I need to I create T/C Planes ALWAYS keeping the created top view WCS active when creating toolpaths. I never create multiple MC9 files for parts. I may on occasion create a new one for fixtures if the MC9 file is getting excessively large, other than that, one file so I can Verify the whole part.
"What works for me is to create the initial Top View using the WCS, then as I need to I create T/C Planes ALWAYS keeping the created top view WCS active when creating toolpaths....one file so I can Verify the whole part."
I use this same process and it works great for me too.
Bruce,
as long as you set the tool plane to bottom, then all will be well. The problem I find with all this is I have to attack the part from multiple sides, so keeping track of all the tool plane numbers is a nightmare. I always set a new WCS for every toolplane and name the view.
Rob
