Run times from set-up sheet
nickz
Did a search and have not found any topics regarding my problem....
When running my set-up sheet, the run-time for my tapping is huge. This is because we are running "Rigid Tapping, (synchronized)" and the G-code macro for this requires FPR, "feed per revolution". This is causing the run-time on the set-up sheet to become unrealistic. Is there some where I can fix this? Post? Config? etc.
The G-code output is correct, its only the run-time that is being processed as if it is FPM (feed per minute) instead of FPR. The pitch is coming out as the feedrate in the G-code correct.
ie. M10 x 1.5 thread,
Fanuc control, metric.
G842 X0. Y0. Z-30. R2.5 F1.5
G95 is in the G842 macro and is the only time we use FPR, all other operations are FPM.
Yes you are correct, sir.
Ok, I am using a Fanuc post and the variable "n_tap_thds" is not in this post. Is this a "system variable" (lack of better description) that I can include into the post or other file? I am using the HTML set-up sheet and I do not completely understand how this system works.
[This message has been edited by nickz (edited 07-27-2001).]
