Vortex post help
Bruce Caulley
Here is what I get
 O1030 (1030)
(MASTERCAM - V9.)
(MC9 FILE - T:MASTERCAMQLDD2282-01REVAD2282-01-102-ROTATED.MC9)
(MATERIAL - NONE)
(PROGRAM - 1030.NC)
(DATE - NOV-16-04)
(TIME - 10:47)
(POST LIC - Ferra Engineering)
(T3 | 8MM ENDMILL ROUGH | H8 | D8 | D8.0000mm | | CONTOUR....)
N100 G00 G17 G21 G40 G49 G80 G90
N102 (MAX | Z50.)
N104 (MIN | Z-9.5)
N106 M08
N108 S10000
N110 G00 G90 A0. B0.
N112 G43.1 H8 Z50.
N114 X-1021.784 Y-13.43 Z-2.85
N116 G01 Z-3.85 F2000.
N118 G03 X-1020. Y-13.85 I1.784 J3.58
N120 G01 X-920.1 Z-4.597
N122 G03 Y-13.35 Z-4.603 I0. J.25
N124 G01 X-1119.9 Z-6.097
N126 G03 Y-13.85 Z-6.103 I0. J-.25
N128 G01 X-1020. Z-6.85
N130 X-920.1 Z-7.597
At line N114 the machine is going straight to the start point and feedplane in one move. The answer must be staring me in the face, but I just can't seem to work it out. How do I get it to mave to its start point at clearance before going to feed plane? Clearance is set at 60mm abs, retract at 40mm abs and feedplane at 1mm inc. The path is 3axis only.
thanks in advance
Bruce
Bruce,
If nobrk doesn't give you what you want change psof and ptlchg so that X (pfxout) and Y (pfyout) is on one line and Z (pfzout) the following line
From PSOF
pcom_moveb
c_mmlt #Multiple tool subprogram call
ptoolcomment
comment
pcan
#if stagetool >= zero, e
pbld, n, *t
n,"M6"
n,"H1", "D2"
n,"M56"
n,"G90", pwcs, e
if lock_codes = 1 & not(index) & rot_on_x, pbld, n, "M11", "(UNLOCK)", e
n, pfcout, e
if lock_codes = 1 & not(index) & rot_on_x & cuttype = 0, pbld, n, "M10", "(LOCK)", e
pindex
#if mi1 > one, absinc = zero
pcan1, pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, *speed, *spindle, pgear, strcantext, e
pbld, n, "G43", "H1", pfzout, *scoolant, e
if mi9 >=1, n, "M77", e
if mi10 >=1, n, "M26", e
if mi6 >=1, n, "M97", e
if next_tool = first_tool, e
else, n, next_tool, e
if mi8 = one & mi7 = one, result = mprint(shspmill)
if mi8 = one, n,"G05P10000(SGI ON)", e
if mi7 = one, n,"G08P1(GI ON)", e
absinc = sav_absinc
Steve,
Yes it does have this set as 0. I have moved the pzout in the rapid motion settings to a separate line and this seems to work, however I end up with a line with nothing but G00 on it. No drama but a bit messy. I will need to run a proper test job in this machine as we haven't sorted this all out yet.
Thanks for your help.
Bruce
