DNC Max
jeff
When I send files to a machine, I have to re-select the full path each time.
It goes to my default folder,but when sending files from sub folders,it doesn't keep a path memory of the last time I sent a file.
Is there a way to fix this?
Will this be fixed in V5.?
OHHHHH...I see...
I never encountered that issue. I have all my programs listed alphabetically in the main folder and I just select what I need from there. I see what you mean...you don't want to have to step through all the subfolders each time you want to send a new program from a subfolder. Other than changing the default path to the desired subfolder, I don't know any other way to do it. Maybe you could use the main folder as a temporary directory for only the active programs you'll be using, and store everything else in its proper subfolder until needed. Either way, it sounds like a pain. Sorry I can't be of any more help.
Hi Jeff,
By default it will remember the last folder, but be aware that this is on a "per port" basis (every time you send to "Port A", it will remember the last directory used when sending a file to "Port A").
However there are several options that can change this behavior:
In the client:
1) Don't check "Setup/Configure Client/Always start in 'root' directory"
2) "Port/Configure Port/Directories/Advanced Directories" - Don't check any of the $SENDROOT options.
Best regards
Tom Mortensen
CIMCO Integration - Development
