Modifing C'Plane
kathy
Hello Everyone!
I have a program where I've imported in a similar program's job setup. My imported SETUP A is at 0,0,0, C'plane #1. The imported SETUP B (0,0,1.32) is using C'plane #4. The rotation form top to bottom is 180 degrees about the Y Axis. HOWEVER--- I would like to modify the rotation to be 180 degrees about the X Axis!. How do I modify the imported SETUP B C'plane?
Thanks for the help,
Kathy
(am I stuck having to delete the existing C'Plane and re-creating in the rotation I need???) frown.gif
Charles,
Where is Modify, xform, between views? My modify dosn;t show it on the menu. V8.1.1.
I don't want to move or change geometry entities, I want the #4 C'Plane to show a different rotation. Right now, if I set gview to SETUP B', the part is turned over, 'fliped' from right to left. I would like to 'flip' the part from top to bottom using the C'plane.!
Thanks, Kathy
Hello,
Simtech, there's somthing here I'm not understanding..?? I don't want to move my geometry; I want to re-define my C'plane. How will translating my geometry do that?
Thanks, Kathy
Jay - these hours are getting old! I havn't seen my boat in over two weeks! keep missing out on the Wednesday Night racing. But it's also football season. check out my web site - I've got the Bobcat's stuff up and running.
Kathy:
First of all, views 1-8 are pre-defined (you can't change them). Second, there is currently no way to "renumber" the views (change view # 37 to view #9 for instance).
You can "combine views" to compact the number of cplanes defined, but you can't really organize them (not 'till v9 at least).
The only way of getting what [i think] you want is to start from view #4 and go to cplane-rotate-about Z, put in the angle, and save it. This creates a new view number (the next unused one). You can then go to cplane-next menu-save named, and give the view a name that you can pull up from anywhere (including importing from another file).
I know that you probably know most of this already, but I figured I'd go through everything just in case others didn't.
[ 08-17-2001: Message edited by: gstephens ]
I read your question yesterday Kathy and I would have said what gstephens just said. I thought what you were getting at was re-defining the c/plane #4 which I didn't know how to do. And apparently you can't, but I usually use stephens trick.
I ended up deleting my orignal SETUP B C'plane (based on C'plane #4 rotation) and re-created the C'plane I wanted. The newSETUP B I created is based on C'plane rotation #9!
I know how to modify a user defined C'plane's orientation, I just thought there was a way to modify the rotation (that I had missed)!
