Solids Question
RStuart
i am trying to create a solid similar to the way that I would create a ruled surface. I basically have two squares that are parallel to each other but at different z depths an are not identical. I am trying to create a solid while maintaining the blend between the two. Solid Sweep?
How about extruding the entire thing as a block and doing the remove in the areas your need. This way you have one solid piece instead of having to do a boolean add.
Don't know if it's the best way....
But it'll work
RStuart, Use solid loft, on the create body page there is a check box to create as ruled.
