yasnac mx1 parameter setting
ken wong
we just bought used masuura MC-760V with yasnac control EN4-00429A and we do not have (see) working coord.offset page to set g54,,,,g59 ,only have H,D offset. i read operator manual it say i have to set parameter #6515......#6519...but i do not have a value to set in
anybody have this experience ,please help
thank alot
Yes Ken
you actually enter your work offset values in the paramters
#6515 = X
#6516 = Y
#6517 = Z
#6518 = A ( I think, never saw 4ax this old)
#6519 = B (same as above here)
You enter your offsets like so,
-13.2456 would be entered without the decimal
-132456
Yes those will need to be changed for every set up that the values change.
it reads from the left 4 decimal places
so if you enter only 1
it will see .0001
if you enter 10000
it will see 1.0000
Ken
I just pulled the manual for that control.
MX1 pdf
Those setting should work for you. Did you try setting them as a negative #?
Check your setting #'s Ken, the manual I looked at listed them as such
G54 X#6516 Y#6517 Z#6518
G55 X#6522 Y#6523 Z#6524
G56 X#6528 Y#6529 Z#6530
[ 11-20-2005, 05:46 PM: Message edited by: jmparis ]
Ken
To input the fixture offsets
Switch to MDI
then use the following command
G10Q2P(value)X(value)Y(value)Z(value)A(value)
(REF. G10Q2P1X-5.276Y-7.485Z-8.010A0.0)
G54=P1
G55=P2
G56=p3
G57=P4
G58=P5
G59=P6
A= 4th axis
as a remender
When you use cutter com.need to use the
D41 and up offset.
Ref. G01G41X-.025D41(D41 TOOL RADIUS)
Hope these help
we have the same amchine, same control
