Inverse feedrate trouble
Bruce Caulley
Hello all, (for the third time today!!)
I have set the control definition to output inverse feedrates for 4th and 5th axis for both linear and rotary output, but it isn't outputting. I have turned invers feedrates on in the post switch, but the variables below may be my problem:
 #Feedrate calculation variables
frdelta : 0 #Calculation for deg/min
frinv : 0 #Feedrate inverse time
frdeg : 0 #Feedrate deg/min actual
prvfrdeg : 0 #Feedrate deg/min actual
ldelta : 0 #Calculation for deg/min, linear
cldelta : 0 #Calculation for deg/min, linear and rotary
circum : 0 #Calculation for deg/min
circuma : 0 #Calculation for deg/min
circumc : 0 #Calculation for deg/min
ipr_type : 2 #Feedrate for Rotary, 0 = UPM, 1 = DPM, 2 = Inverse
rotary_arm : 0 #Calculation for deg/min
tilt_arm : 0 #Calculation for deg/min
Should any of the other values be something other than 0??
Bruce
Thanks John, but no dice.
This is what I get no matter what:
 0  BEGIN PGM  1003 MM
1 ; PROGRAM NAME - 1003
2 ; DATE=DD-MM-YY - 17-12-05 TIME=HH:MM - 10:36
3 ; POST LICENSE - Ferra Engineering
4 ;
5 ; DEFINE TOOL NAMES
6 M129
7 ;
8 L Z-1 F MAX M91
9 L X-495 Y-350 R0 F MAX M91
10 ;
11 TOOL CALL 50 Z S1010
12 ;
13 CYCL DEF 32.0 TOLERANCE
14 CYCL DEF 32.1 T0.01
15 ;
16 CYCL DEF 7.0 DATUM SHIFT
17 CYCL DEF 7.1 # 0
18 ;
19 CYCL DEF 10.0 ROTATION
20 CYCL DEF 10.1 ROT 0
21 ;
22 CYCL DEF 19.0 WORKING PLANE
23 CYCL DEF 19.1 A+0 B+0 C+0
24 L B+Q121 C+Q122 F MAX M126
25 ;
26 ;
27 ; TOOLPATH - FINISH5
28 ; STOCK LEFT ON DRIVE SURFS = +0
29 CYCL DEF 19.0 WORKING PLANE
30 CYCL DEF 19.1
31 M128
32 L X-80.175 Y-52.67 F MAX ; CLEARANCE FOR TABLE ROTATION
33 L Z+2.611 F MAX ; CLEARANCE FOR TABLE ROTATION
34 L B+180 C+301.54 F MAX
35 L X-37.561 Y-26.515 Z+2.611 R0 F MAX M13
36 L X-24.777 Y-18.669 F MAX
37 G94 L X-20.032 Y-17.7 Z+1.368 F400
38 L X-20.168 Y-17.849 Z+1.506 C+305.125 F300
39 L X-20.306 Y-18.01 Z+1.632 C+308.886
40 L X-20.434 Y-18.173 Z+1.741 C+312.588
41 L X-20.558 Y-18.346 Z+1.838 C+316.349
42 L X-20.677 Y-18.532 Z+1.923 C+320.209
43 L X-20.781 Y-18.718 Z+1.991 C+323.892
44 L X-20.874 Y-18.912 Z+2.046 C+327.536
45 L X-20.953 Y-19.095 Z+2.085 C+330.88
46 L X-21.028 Y-19.294 Z+2.115 C+334.411
47 L X-21.098 Y-19.509 Z+2.133 C+338.094
48 L X-21.157 Y-19.738 Z+2.139 C+341.889
49 L X-21.2 Y-19.955 Z+2.133 C+345.369
50 L X-21.231 Y-20.183 Z+2.115 C+348.936
51 L X-21.251 Y-20.425 Z+2.084 C+352.623
52 L X-21.255 Y-20.672 Z+2.04 C+356.321
53 L X-21.246 Y-20.923 Z+1.983 C+360.032
54 L X-21.221 Y-21.189 Z+1.91 C+363.919
55 L X-21.178 Y-21.445 Z+1.827 C+367.642
56 L X-21.116 Y-21.698 Z+1.733 C+371.301
57 L X-21.035 Y-21.949 Z+1.627 C+374.973
58 L X-20.934 Y-22.201 Z+1.505 C+378.712
59 L X-20.814 Y-22.456 Z+1.367 C+382.568
60 L X-20.674 Y-22.703 Z+1.216 C+386.434
61 L X-20.516 Y-22.937 Z+1.054 C+390.258
62 L X-20.34 Y-23.159 Z+.88 C+394.077
63 L X-20.147 Y-23.368 Z+.694 C+397.925
64 L X-19.937 Y-23.565 Z+.493 C+401.837
65 L X-19.715 Y-23.741 Z+.285 C+405.715
66 L X-19.486 Y-23.893 Z+.073 C+409.483
67 L X-19.251 Y-24.024 Z-.144 C+413.216
68 L X-19.008 Y-24.135 Z-.367 C+416.957
69 L X-18.764 Y-24.224 Z-.592 C+420.647
70 L X-18.52 Y-24.294 Z-.821 C+424.335
71 L X-18.265 Y-24.348 Z-1.063 C+428.207
72 L X-18.019 Y-24.379 Z-1.298 C+431.944
73 L X-17.774 Y-24.389 Z-1.534 C+435.723
74 L X-17.543 Y-24.381 Z-1.759 C+439.346
75 L X-17.325 Y-24.357 Z-1.972 C+442.834
76 L X-17.098 Y-24.317 Z-2.198 C+446.607
77 L X-16.884 Y-24.266 Z-2.414 C+450.301
78 L X-16.684 Y-24.204 Z-2.616 C+453.877
79 L X-16.5 Y-24.133 Z-2.802 C+457.302
80 L X-16.332 Y-24.056 Z-2.971 C+460.545
81 L X-16.154 Y-23.962 Z-3.149 C+464.121
82 L X-15.978 Y-23.858 Z-3.323 C+467.825
83 L X-15.802 Y-23.742 Z-3.493 C+471.684
84 L X-15.639 Y-23.621 Z-3.645 C+475.43
Not a change in feedrate to be found anywhere. headscratch.gif I get the same result with 4 or 5 axis output.
I might have to do this in V9 afterall.
Bruce
Just noticed the G94 on line 37 above. This the ancestor of this post is ISO/Fanuc it looks like I need to substiture this with the Heidenhain M code for inverse feed. I tried using M116, but that can only be used in one plane and not with M128 active. (true?)
Anyone know what the M code for inverse feed is on a TNC430 controller?
Any suggestions????
Bruce
Thanks Sleepy and Pip, but I need the heidi equivalent of G93/G94. It should be an M code, but since this post must have been modified from an ISO one I think a couple of the less used functions weren't converted over. Looking through the manual I don't see anything other than M116 which only works in one plane, so can't really be what I am after. I will send an email off to Dave Thompson first thing in the morning.
Bruce
Remember that a pre-X post may not use all control def variables.
I believe that the M128 TCPM 5-Axis comp is tied directly to the interpretation of the linear mm/min feed based on the kinematic model of the machine as defined by parameters on your control. To disable this feed interpretation, you'd need to disable M128. Your post is not configured for this from a coordinate mapping standpoint, or a tangential velocity standpoint (used in the calculation of inverse feeds).
To get inverse feeds in our posts, in a post that supports them, and on a control that supports them, you'd need these settings:
use_frinv : 1
rot_feed : 1
With rot_feed set to 0, use_frinv has no effect.
