Post "spray mist problems"
Bruce
I am running mill 8.11 and using a MPHEI370.pst. Ever time I try to use the mist and run the post this error message appears.
Selector variable Spdlsel = 8.0
out of range for string select.
I can't find a M function to turn on the mist & spindle at the same time but is it possible to output code to turn on the mist on a line before or after the spindle starts.
Roger Martin hooked me up for this one.
If you know the "M" code for mist it should be easy. This is what mine looks like:
sm09 # Coolant off
sm08 M7M8 # Coolant on - FLOOD selection
sm07 # Coolant on - MIST selection
sm06 # Coolant on - TOOL selection
smcool # Coolant code target string
I turn spindle water and flood water on after the first rapid move and before the spindle starts. Putting your "M" code in front of the "mist" line will generate a seperate line with your m code when mist is selected in tool parameters window. Note: tool parameters window (in op manager)coolant selection is set by the coolant type you selected in the tool itself, however you can change it in the tool parameter window if you need to.
As for your error message, I'm sure you will get a reply soon.
My prapid lines look like this:
pctr_flags1 #
n, sccomp, pgcode, x, y, z, pfr, pcan
n, pcoolon # Coolant ON
n, *ss, *spdlon # Tri-dundancy line
pctr_flags2 #
The "pcoolon" will output whatever you told it to in the tool parameters window.
Oh the power of a post
I hope I haven't missed anything.
Dave
Yes you are right, I do have a combined spindle/coolant string and yes the post is V6 era. I tried Jim's idea and it turned the mist on in the line before but I still got the same error message in the next line. What's mist callout, sorry still learning. I will play around with it over the next few days and see how I go.
The combined coolant / spindle string lookup must be expanded to cover all the coolant types. Chances are you only have off and flood covered. You need to expand the table for each possible coolant type (in sets of three for each spindle state).
sm04 M4 # Spindle reverse - no coolant
sm05 M5 # Spindle off - no coolant
sm03 M3 # Spindle forward - no coolant
sm04f M14 # Spindle reverse - with flood coolant
sm05f M5 # Spindle off - with flood coolant
sm03f M13 # Spindle forward - with flood coolant
sm04m M14 # Spindle reverse - with mist coolant
sm05m M5 # Spindle off - with mist coolant
sm03m M13 # Spindle forward - with mist coolant
sm04t M14 # Spindle reverse - with thru tool coolant
sm05t M5 # Spindle off - with thru tool coolant
sm03t M13 # Spindle forward - with thru tool coolant
spdlon # Target Spindle-on M-string
spdlsel = coolant * 3 + fsg3(ss) # Spindle on selector based on
# coolant - 0 = off, 1 = on
fstrsel sm04 spdlsel spdlon
Dave
I tried this and still had problems. I solved the problem by forcing a M03 ( I dont run the machine in reverse so it's not a problem) at the program start and at tool changes. I then introduced "smcool" in the line before for the coolant & mist control.
