HTML.SET
kccadcam
Kevin,
Was this previously working in MR1?
Did you do a new install for MR2 or just move the files into the correct directory.
You might want to make sure you are pointing to the correct directory for the MR2 setup sheet.
Directories not being pointed to the correct MR2 folders seems to be one of the biggest problems people are having with the MR2 install, especially the side by side installs.
Did you get rid of that FixedSetupSheet.dll as your Setup Sheet type - make sure it's set to .SET.
Only 2 things changed for MR2. toolbmp.dll is updated for MR2. And there was a mod to the html_gif.vbs and html_png.vbs screen cap scripts to allow for long directory install paths like "C:Program FilesMcamx"
Did not do a side by side install. Loaded MR2
over MR1.
Did a fresh install of MR2 HTML.set.
The fixedsetupsheet.dll was still there but not selected.
I removed that file and now I still get that same OnScript error but it also gives me "Increase max_toolno variable in .set file - Program will Exit"
Our tool numbers start at 1000 and go up from there.
If I change max_toolno from 99 to 9999 it just crashes...........
Finally got it to run....
Only 6 trials left!!!!
mill_accel : 1 # Accelerate processing time for Mill or Router only setup sheets [0=No,1=Yes]
max_toolno : 9999 # Maximum tool number (not including lathe offset portion of tool call)
# The 'stock_info' switch allows selecting to output detailed Stock Information
stock_info : yes$ # Display Part location, stock size/location
stock_img : 1 # 0 = No screen capture image
# 1 = EMF: auto image cap, fast run, large file size, bad on-screen, prints perfectly -
not supported by Firefox/Mozilla
# 2 = PNG: auto image cap, slow run, small file size, clean on-screen, prints reasonably
# 3 = GIF: auto image cap, slow run, small file size, clean on-screen, prints reasonably
# 4 = GIF: manual image cap, searches for pre-existing GIF
# [NC_directory][ncfilename].[sextgif] for file_naming = 0
# [MCX_directory][mcxfilename].[sextgif] for file_naming = 1
slaunch "C:Program FilesInternet Exploreriexplore.exe"
