contour
Tom
I'm working on a simple 2D contour ( a circle ) In this program, I need to program such that the cutter starts at the bottom ( final depth )
of the contour first and then cuts contour several paths upward ( rough step)
I'm wondering if there is a way to do that without defining mutiple circles and operations
I'm using V8.1.1
Tom,
I tend to agree with Jay. I tried to repeat what you wanted to accomplish with the Circle Toolpaths. Circle mill is similar to a Contour but always starts from the top. Thread mill has a Helical contour and will start from the bottom and go to the top but has no roughing method. I tried to mirror or rotate the circle mill toolpath to see if I could get it to start at the bottom and work up, but that wasn't working either. frown.gif
Actually, you may be able to create a Circle mill toolpath, Transform rotate it from the Front Cplane and then post it out. You would then have to edit the NC code file so it wouldn't attempt to rapid and feed the tool from the backside of your part. smile.gif Hope this gives you some ideas.
Tom, It's not too hard.
I got a .5 mill interpolating a 3.0 bore from the bottom up in 4 steps of .25 increments. Edit one line of posted code and your set.
TA,1
N1O0000(PART)
N2G0G17G40G49G80G90H0E1Z0
N3T20M6(.499 DIA END MILL DIA. - .499)
N4G0G90S3000M3E1X1.2505Y0.
N5H20Z.25
N6A-0
N7G1Z-1.F11.
N8G3X0.Y1.2505I-1.2505F24.
N9X-1.2505Y0.J-1.2505
N10X0.Y-1.2505I1.2505
N11X1.2505Y0.J1.2505
N12G0Z.25
-------DELETE THIS LINE--------
N13Z-.75
N14G3X0.Y1.2505I-1.2505
N15X-1.2505Y0.J-1.2505
N16X0.Y-1.2505I1.2505
N17X1.2505Y0.J1.2505
N18G0Z-.5
N19G3X0.Y1.2505I-1.2505
N20X-1.2505Y0.J-1.2505
N21X0.Y-1.2505I1.2505
N22X1.2505Y0.J1.2505
N23G0Z-.25
N24G3X0.Y1.2505I-1.2505
N25X-1.2505Y0.J-1.2505
N26X0.Y-1.2505I1.2505
N27X1.2505Y0.J1.2505
N28M5
-------ADD A RETRACT HERE FOR SAFTEY--------
N29G91G0H0Z0.
N30E0X0Y0
N31M30
Program the first cut to the depth wanted.--Z-1.
do consecutive COPY AFTER'S in the Ops Manager. Then set the Z depth in each of the OPs. THEN.......
TOOL PARAMETERS TAB /Change NCI button/ ensure "force toolchange" is UNCHEKED.
CONTOURS PARAMETER TAB on each OP.
uncheck Clearance
uncheck retract
set FEED PLANE = to depth of cut.
KLG
At first, I would like to thank you very much for all the replies and solutions to my question
In reply to you folks question earlier. I will describe a little more detail what I'm trying
to do smile.gif . I'm working on a program to cut a body of a mutiple pin electrical connector.
In this program, after drilling more than 100 deep holes, I need to put an undercut near bottom of each drilled holes
To cut these undercuts. We modify a carbide endmill to a very small diameter keyseat cutter.
The width of the cutter is much smaller than the undercut area that need to be cut to reduce the pushing force to the endmill
Therefore. It needs to travel several paths and technicaly, We want it starts to cut in the middle of the area. Cuts a
Because, This whole operation will then be transformed to another 108 locations ( 108 pin connector )
so I'm afraid any transformed toolpath in the source operation would not be working in this particular case
