Fadal post needed help .
Jimic
I am working to have a clean post without any editing.
How do I change my Fadal Post so that on my Nc file. The option that I called up ??
On the output Comment to NC file
- output group name
- output operation commemt to Nc
- machine name
That output will be below the file name.
O12345 (12345)
(output group name)
(output operation commemt to Nc)
(machine name)
Right now that have it in On top of every toolchange.!!!
Thankx
P/s Peter might have the right answer for me smile.gif
Look for strings similar to the one below your "ptlchg_com" section and copy them to either your "psof" section or "pheader" section. Notice the pound sign at the beginning of the line. The blocks out the command. Leave the original, block it out, and copy the line to where it gives you the output you want.
#if stpgrpname <> snull, pbld, n$, pspc, "(TOOLPATH GROUP - ", stpgrpname, ")", e$
Go into your control def >> nc output >> and click on debugging and post something, look at the corresponding section of the post that is listed next to those things to see what is actuallly causing them to output
John,I done as you suggested.That cause by ptlchg$ pcomment2
What this 1006, 1007, 1008
if gcode$= 1006 pbld,n$, pspc, "(", scomm$, ")" #Comments
pcomment2 #Comment from manual entry
spaces$ = 0
scomm$ = ucase (scomm$)
#1005 - Comment option 1
#1006 - Comment option 2
#1007 - Define comment with output line
#1008 - Define NC parameter comment
#1026 - ?
if gcode$ = 1005, pbld, n$, pspc, "(", scomm$, ")"
if gcode$ = 1006, pbld, n$, pspc, "(", scomm$, ")" #Comments
#if gcode = 1006, pbld, n, pspc, scomm #Codes
if gcode$ = 1007, "(", scomm$, ")"
if gcode$ >= 1008, pbld, n$, pspc, "(", scomm$, ")"
if gcode$ = 1026, pbld, scomm$
if gcode$ <> 1007 & gcode$ <> 1026, e$
spaces$ = sav_spc
% pheader$ pheader$
O5566 (HOLE) pheader$ pheader$
(PROGRAM - HOLE.NC) pheader$ pheader$
(DATE - OCT-18-06) pheader$ pheader$
(TIME - 16:34) pheader$ pheader$
(T1 | 1/2 SPOTDRILL | H1 | D1 | D0.5000" | DRILL/CBORE) pwrtt$ pwrtt$
(T2 | NO. 32 DRILL | H2 | D2 | D0.1160" | PECK DRILL.) pwrtt$ pwrtt$
(T3 | 1/8 REAMER | H3 | D3 | D0.1250" | DRILL/CBORE) pwrtt$ pwrtt$
(OVERALL MAX | Z.1) psof$ p__31:1165
(OVERALL MIN | Z-1.5) psof$ p__31:1165
G90G80G40G17G0 psof$ psof$
(FADAL) psof$ pcomment2
(TESTING AUTODRILL) psof$ pcomment2
(** SPOT FOR .125 REAM,**) psof$ pcomment2
N1M6T1( 1/2 SPOTDRILL) psof$ ptoolcomm
(MAX | Z.1) psof$ p__34:1202
(MIN | Z-.07) psof$ p__34:1202
M3S1000 psof$ p__33:1199
G0G90X2.824Y-3.6706G54 psof$ p__33:1199
G43H1Z.1M8T2 psof$ p__33:1199
G81G99X2.824Y-3.6706Z-.07R.1F4. pdrill$ pdrill$
X4.907Y-3.87 pdrill_2$ pdrill_2$
G80M9 pcanceldc$ pcanceldc$
G0M5 ptlchg1002$ pretract
G91G28Z0. ptlchg1002$ pretract
M1 ptlchg$ ptlchg$
(FADAL) ptlchg$ pcomment2
(TESTING AUTODRILL) ptlchg$ pcomment2
(** DRILL FOR .250 REAM **) ptlchg$ pcomment2
N2M6T2( NO. 32 DRILL) ptlchg$ ptoolcomm
(MAX | Z.1) ptlchg$ p__34:1202
(MIN | Z-1.5) ptlchg$ p__34:1202
M3S3000 ptlchg$ p__33:1199
G0G90X2.824Y-3.6706G54 ptlchg$ p__33:1199
G43H2Z.1M8T3 ptlchg$ p__33:1199
G83G99X2.824Y-3.6706Z-1.5R.1Q.15F12. ppeck$ ppeck$
X4.907Y-3.87 ppeck_2$ pdrill_2$
M1 ptlchg$ ptlchg$
(** REAM FOR .125 HOLE **) ptlchg$ pcomment2
N3M6T3( 1/8 REAMER) ptlchg$ ptoolcomm
