setup sheet post help
dan m
I am tweeking my setup sheet and have it almost perfect and was wondering if there is a way to get the dim's from my stock setup imported onto the sheet. I have it where it will give the min/max of what is programmed but i want the actual stock size. the 6.825 is where the tool rapids to the stock size is 6.75 and the .25 is a 1/4 in front of the part the part length is 1.75
Program Name = Test
Date = Oct - 19 - 06
Stock Size = X +6.8250 Z +0.2500
Program Number = 8198
TOOL LIST
Num. Off. Rad. Description/Comments
4 4 .0313 ROUGH FACE
4 4 .0313 FINISH TURN
12 12 .8750 1 3/4" WAUKESHA DRILL
8 8 .0313 1 1/4" ROUGH BORING BAR
10 10 .0313 1 1/4" FINISH BORING BAR
[ 10-19-2006, 10:20 PM: Message edited by: dan m ]
Under
# Optional Output Settings
stock_info: yes$ #Display stock material and size/location?
Then I have
# Format assignments
fmt X 7 stck_ht$ #X - Stock Height
fmt Y 7 stck_wdth$ #Y - Stock Width
fmt Z 7 stck_thck$ #Z - Stock Thickness
fmt X 2 stck_x$ #X origin of block
fmt Y 2 stck_y$ #Y origin of block
fmt Z 2 stck_z$ #Z origin of block
fmt 2 stck_crnr$ #Origin corner of stock
In the header section I have
pheader$ #Call before start of file
pstock_info #Stock information output
Then further down I have this"
pstock_info #Output stock information if requested
if stock_info,
"MATERIAL TYPE = "
if stck_matl$ = "NONE" | stck_matl$ = "", "*NOT DEFINED*", e$ #No material type was selected
else, stck_matl$, e$
#" ", e$ # Blank line
if stock_info & tlplnno$ <= one, #ONLY if in TOP plane
#If any stock values are empty, disable don't output
if stck_ht$ > 0 & stck_wdth$ > 0 & stck_thck$ > 0,
"STOCK SIZE = ", stck_ht$, " ", stck_wdth$, " ", stck_thck$, e$
"STOCK ORIGIN = ", stck_x$, " ", stck_y$, " ", stck_z$, "(", *stknote, ")", e$
