Haas post, M9 issues
DaveR
I am using a new VF-2, and X2. The coolant comes on at the right time at spindle start but it turns off as the z axis hits home at tool change splashing my tapers. How do I change the timing in the post so it turns off at retract from the part for tool change?
(I'm a post mod rookie)
Thanks for any assistance.
Dave
Hi Dave,
You can make the modification in the pretract post block. Add the following line before the home position retract move:
pbld, n$, scoolant, e$
pretract #End of tool path, toolchange
sav_absinc = absinc$
absinc$ = one
sav_coolant = coolant$
coolant$ = zero
# if nextop$ = 1003, #Uncomment this line to leave coolant on until eof unless
[ # explicitely turned off through a canned text edit
if all_cool_off,
#all coolant off with a single off code here
if coolant_on, pbld, n$, *sall_cool_off, e$
coolant_on = zero
else,
local_int = zero
coolantx = zero
while local_int < 20,
coolantx = and(2^local_int, coolant_on)
local_int = local_int + one
if coolantx > zero,
coolantx = local_int
pbld, n$, scoolantx, e$
coolantx = zero
coolant_on = zero
#cc_pos is reset in the toolchange here
cc_pos$ = zero
gcode$ = zero
pbld, n$, sccomp, *sm05, psub_end_mny, e$
pbld, n$, scoolant, e$ <---------------ADD THIS LINE OF CODE TO THE (pretract) POST BLOCK
pbld, n$, sgabsinc, sgcode, *sg28ref, "Z0.", scoolant, e$ <-----------YOU CAN DELETE THE [ ,scoolant ] HERE IF YOU WANT AS WELL
if nextop$ = 1003 | tlchg_home, pbld, n$, *sg28ref, "X0.", "Y0.", protretinc, e$
else, pbld, n$, protretinc, e$
absinc$ = sav_absinc
coolant$ = sav_coolant
