Digitized text in MC X
masnart39
I have a digitized surface saved as a .txt file. I would like to open this in MC X as lines, and modify the shapes of some of these lines.
I have done this in MC v9 by doing the following:
NC utility > post process > reverse > run > NC utiliy > backplot > display > save as geometry.
At that point, I have a 3d line drawing, and I can edit the lines to the desired shapes.
Is there a somewhat simple way to do the same thing in MC X ? It seems as though this should be a basic process, but with the change in screen layout, I'm having a very difficult time trying to figure this out.
Thanks in advance for any help !
Thanks for the welcome, John.
I have been able to open the file using the ASCII(.txt), but it opens as points, and I haven't been able to figure out how to convert them into a line.
To be more specific...
The digitizing probe starts at an x,y,z point, and moves across the x axis, sampling and recording changes in the z axis. At the pre-determined x position, the probe moves in the y axis .100", and begins back down the x axis in the opposite direction. For my purposes, it is one continuous tool path, except that it is a series of points .100" apart. We are already cutting with this file. The machine loads the tool, and cuts the path. I want to keep it as one tool path(x,y), but modify some of the protrusions (z axis). It seems easiest to have this toolpath as a line, and delete some of the protrusions I'd like to eliminate, and replace them with straight lines.
I hope I've explained what I'm trying to accompish a little more clearly. I'm just in the process of learning mastercam through an online video course, which doesn't explain how to do this..
Thanks again,
Mike
Thanks Cuda84,
I'll give that a try.
Allan,
I've tried choosing lines and splines before asking here.... both resulted with nothing on the screen. After looking through the help topics, it seemed that this would have been exactly what I was looking for, but to my surprise, no go.
Mike
What does your file format look like?
I just tried something simple like:
X1.313774 Y0.4931055 Z0
X0.8805456 Y-0.1620204 Z0
X0.7854466 Y0.3909622 Z0
X0.1232764 Y-0.07748801 Z0
X-0.19372 Y0.3909622 Z0
X-0.8136241 Y-0.0598771 Z0
X-1.007344 Y0.4790168 Z0
X-1.310252 Y0.232464 Z0
Chose lines in the options and I got lines.
Let see what your file looks like.
Allan
Here's some of the code. I left a blank line where I skipped some of the code to show the x move, and change in direction. I have tried loading it without the G code as well.
Something I began to think about, was that for whatever reason, maybe it's going to a different level when I try to open it as lines, and the level isn't visible. I'll have to check that later and see if that's the case.
G17G40G49G80G90G54
T3M6
G0G90X2.100Y-9.035S3100M3A135.
G43H3Z3.5F42.
G1Z3.5
X2.1000Y-9.0350Z2.6970
Y-8.7499Z2.6970
Y-8.7249Z2.7244
Y-8.6999Z2.7489
Y-8.6749Z2.7714
Y-8.6499Z2.7915
Y-8.6249Z2.8096
Y-8.5999Z2.8263
Y-3.4749Z3.0814
Y-3.4499Z3.1047
Y-3.4249Z3.1288
Y-3.3999Z3.1529
Y-3.3800Z3.1704
X2.1500Y-3.3800Z3.1176
Y-3.4050Z3.0929
Y-3.4300Z3.0679
